First post, by DevilTenchi
I've identified some components on this motherboard that need to be replaced. I can solder just fine, but I'm not good at figuring out data sheets. Can I please get some help identifying a modern transistor replacement and what the other part is? Parts went up in smoke testing a CPU in 3V mode, now marked as bad. Now board will not post. Transistor now tests as a short.
Parts to replace
CPU Power Transistor - HSMC BU406B
Part that is in the same circuit, looks like a green resistor. - (Color Bands left to right) R BL BL R R
Pic
https://drive.google.com/file/d/1BdYcfL2tiuUK … ?usp=drive_link
Thanks everyone.
Reply 1 of 8, by dominusprog
For the transistor you'll need an NPN 16V 5A (or higher) power transistor. The resistor is 220Ω 2%.
https://www.ebay.com/itm/284411225925?itmmeta … ABk9SR66r7oPeYw
https://html.alldatasheet.com/html-pdf/2596/M … 44/1/BU406.html
https://www.calculator.net/resistor-calculator.html
Reply 2 of 8, by DevilTenchi
dominusprog wrote on 2024-04-18, 08:11:
For the transistor you'll need an NPN 16V 5A (or higher) power transistor. The resistor is 220Ω 2%. […]
Should I worry about the B at the end of the transistor model?
Does the green body of the resistor indicate a high tolerance? I was getting conflicting search results that it might be a choke.
Thanks
Reply 3 of 8, by dominusprog
DevilTenchi wrote on 2024-04-18, 13:11:
Should I worry about the B at the end of the transistor model? Does the green body of the resistor indicate a high tolerance? I […]
Thanks
No, don't worry about that, here is another model that you can use. You'll need an NPN bipolar transistor (BJT).
19.43 KiB
For the resistor, the last band determines the tolerance.
Reply 4 of 8, by DevilTenchi
dominusprog wrote on 2024-04-18, 14:20:
Thanks
Thanks for all the help.
I can't find any green body resistors in this value, just blue. Ideas on that? Fuse resistor or choke?
Reply 5 of 8, by Deunan
DevilTenchi wrote on 2024-04-18, 18:01:
If the PCB markings say R something it's most likely a resistor. A choke would be L, though obviously last minute design or manufacturing changes are possible. That being said I think it's a resistor, and not a fusible one (these ones tend to be bigger and in general don't have a shiny coating to better dissipate the heat).
Also my eyese might be deceiving me but I think it's a brown - red - black -black - red, which would make 120 ohms rather than 220. Which is way more likely to smoke if one side is connected to 12V and the other was shorted to GND. 220 ohm resistor would get hot but probably not smoke.
Reply 6 of 8, by dominusprog
Thanks
You're welcome. As mentioned, it is a resistor and the value is 120Ω not 220Ω, the brown and red coloring is very close.
Reply 7 of 8, by DevilTenchi
Thanks for the help everyone.
Clipped the resistor off and put it under a magnifier, does look like the first band is brown.
I looked at pictures of the board on The Retro Web and it looks like the manufacturer used whatever body color they had.
Hope this is all that went bad, I guess I'll know once the parts arrive.
I did find that green body resistors usually indicate a pulse power/surge resistor.
Learned something....
Reply 8 of 8, by majestyk
Just my two cents about the resistor:
I think it´s clearly red/black/black/red/ brown = 20KOhm, 1%
Did you measure the resistance with one leg open? I doubt it´s even broken.
Q4 is probably an adjustable shunt (TL431) and should also be checked. Resistors in the 20KOhms range for adjusting the voltage are typical in this case.
