No beep codes from motherboard
First post, by johnvosh
Good day! I recently picked up an ASUS P5NSLI motherboard in unknown condition for free, hoping it would work for my E6700 I had sitting around collecting dust. I got it home, installed the CPU, one stick of DDR2 ram, and a video card and got nothing. It will turn on, the fans spin (the video card fan stays on high), but no post or anything on the screen. I tried without the ram and no beeps. So I uninstalled the video card and the CPU and I could get it to turn on, but still no beep codes.
Looking the board over and nothing looks bad. All the cap's look good, no damage at all. Could the motherboard just be dead or could it be my CPU?
Thanks for the help!
Reply 1 of 32, by Nexxen
A pic?
Is the video card selector present?
https://theretroweb.com/motherboards/s/asus-p5nsli
I'd read the manual for unusual settings.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 2 of 32, by johnvosh
Nexxen wrote on 2024-04-23, 13:03:
A pic?
Reply 4 of 32, by johnvosh
Nexxen wrote on 2024-04-23, 13:23:
You could try by reprogramming the bios.
Deox the cpu socket.
You don't have a POST card? That could help.
I just bought a post card this weekend from eBay, waiting for it to get here. I don’t have any “deox “.
Should it give beeps with no cpu though? I always thought it did.
Reply 5 of 32, by Nexxen
johnvosh wrote on 2024-04-23, 15:12:
I just bought a post card this weekend from eBay, waiting for it to get here. I don’t have any “deox “. […]
Maybe try some alcohol, if they are somewhat oxidized it could avoid cpu to work.
Go light on it.
No cpu it shouldn't beep, with a cpu it should. Not all did, maybe the manual says something.
Reply 7 of 32, by CoffeeOne
johnvosh wrote on 2024-04-23, 13:15:
There is no sticker on the Bios, so maybe somebody played around with it.
Without a Bios nothing happens.
EDIT: Of course without CPU it is the same. Even if it can beep without memory, minimum should be CPU and RAM.
Reply 10 of 32, by johnvosh
Karbist wrote on 2024-04-23, 18:58:
I see discoloration under the north bridge, hopefully solder joints are not cracked under the chip, not a big fan of nForce motherboards with passive cooling.
I removed the chipset heatsink and everything was looking good, no discolouration. It could be the angle of the camera and light....
Reply 11 of 32, by johnvosh
I took and reseated everything, but a fresh battery in. I even took and removed the heatsink from the CPU and had my finger on the power switch of the PSU. The CPU is getting warm, slowly, so I'm guessing that means the CPU is working? I have tried two different video cards and no difference.... Even tried without a video card in and still no beep saying that it has posted or anything.
Reply 13 of 32, by Karbist
johnvosh wrote on 2024-04-24, 00:32:
The copper on back of the board beneath the north bridge has darker color in your pic.
46.52 KiB
Reply 17 of 32, by johnvosh
kotel wrote on 2024-04-26, 17:10:
Can you post a pic of the north bridge?
Reply 18 of 32, by johnvosh
goofyahhuncle wrote on 2024-04-26, 07:20:
Have you tried testing the CPU in another board or swapping in a different CPU?
Unfortunately I don't have another CPU that will work in this board. This CPU was pulled from a working system.
Reply 19 of 32, by PcBytes
nForce 4 SLi. Forget fixing it, it's bumpgate and nothing will fix it because it's the substrate that has gone bad.
I have had several nForce 4 boards (both AMD and Intel) that have went to the trash for that reason alone - bumpgate riddled chips that did not get a revised version with fixed bumps.
