Reply 52740 of 53294, by rav85
BitWrangler wrote on 2024-04-24, 19:41:I think you are seeing the COAST module.
mtest001 wrote on 2024-04-24, 19:39:rav85 wrote on 2024-04-24, 19:24:I got one like this, it starts and works Pentium 200 MMX 128MB Edo MATROX 590 05 […]
Pentium 200 MMX
128MB Edo
MATROX 590 05What motherboard is this ?
Do you have a mix of EDO and SD-RAM?EIDT: Ha no I presume this is the L2 cache module ?
Any idea what it is?
Broken chips 🙁
It is a some sort of motor controller, that has suffered a catastrophic failure...
One chip two chip, dead chip blew chip. If not motors, some other high power inductive load.
Wow, that's one for letting out the magic smoke 😲
Left a big enough hole to get it back in though, go to grocery store and get a bottle of liquid smoke flavoring and a turkey baster...... 🤣
I loved the boxed versions hardware
part.2
and more photos
Good some parts for rebuilding my Voodoo 3 System
Gigabyte GA-7IXE mainboard
Athlon 700 mhz ( K7700MTR51B) Cpu
Tiido wrote on 2024-04-25, 07:58:It is a some sort of motor controller, that has suffered a catastrophic failure...
I was wondering what you could be driving that would cause you to detonate a DAC. That would also explain the fuse and external power input on the inner edge.
Jccwu wrote on 2024-04-25, 15:42:and more photos
Love the Voodoo cards casually piled up like it's nothing. 😁
Great haul.
PC@LIVE wrote on 2024-04-24, 22:49:For the PC XT I found an interesting solution, for the video card, I have an 8-bit ISA, which should be a Hercules (or a monochrome one), the connector for the monitor is with 9 pins, unlike VGA monitors that have 15 pins, so to solve I had to find an 8-bit ISA VGA, or a monitor with 9 pin input, or a 9 to 15 pin adapter.
After various searches, I found a fairly inexpensive solution, a connection cable to the monitor, with VGA port on one side and 9-pin port on the other.
Just replace it with that of the monitor, which has two VGA input outputs, and connect the 9-pin to the Hercules ISA 8-bit, while the other goes to the VGA monitor.
There are some early VGA cards that have a 9pin connector, but if that's not what you have in your XT, that's not gonna work. I assume you have some sort of CGA or Hercules card and this will definitely require signal conversion if you want to use a VGA monitor.
MMaximus wrote on 2024-04-25, 16:27:PC@LIVE wrote on 2024-04-24, 22:49:For the PC XT I found an interesting solution, for the video card, I have an 8-bit ISA, which should be a Hercules (or a monochrome one), the connector for the monitor is with 9 pins, unlike VGA monitors that have 15 pins, so to solve I had to find an 8-bit ISA VGA, or a monitor with 9 pin input, or a 9 to 15 pin adapter.
Yes, exactly, I want to use an 8-bit ISA card, probably Hercules (or CGA), which has a 9-pin video output. Using the cable I ordered, it will connect the video card (9 pin) to the VGA monitor (15 pin). The only doubt is whether the Hercules frequencies are supported by the VGA monitor, because otherwise I would have to find a monitor that has no problems with those frequencies.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
PC@LIVE wrote on 2024-04-25, 17:30:MMaximus wrote on 2024-04-25, 16:27:PC@LIVE wrote on 2024-04-24, 22:49:For the PC XT I found an interesting solution, for the video card, I have an 8-bit ISA, which should be a Hercules (or a monochrome one), the connector for the monitor is with 9 pins, unlike VGA monitors that have 15 pins, so to solve I had to find an 8-bit ISA VGA, or a monitor with 9 pin input, or a 9 to 15 pin adapter.
It's not just the frequencies.
MDA,CGA & EGA all output TTL signal levels 5V (If I recall correctly)
While VGA is analog output max signal level is 0.7V maybe 1V.
Do not ask Why !
weedeewee wrote on 2024-04-25, 17:33:It's not just the frequencies. MDA,CGA & EGA all output TTL signal levels 5V (If I recall correctly) While VGA is analog output […]
PC@LIVE wrote on 2024-04-25, 17:30:MMaximus wrote on 2024-04-25, 16:27:There are some early VGA cards that have a 9pin connector, but if that's not what you have in your XT, that's not gonna work. I assume you have some sort of CGA or Hercules card and this will definitely require signal conversion if you want to use a VGA monitor.
Ouch, if so and probably yes, I spent money on a cable that will be of no use, honestly I didn't know this Volt thing, at this point the only solution is a 9-15 pin converter, I've seen one used in Necroware, I don't know what it costs but the alternative to that is a VGA ISA 8 bit like trident or gremlin.
Just got the one on the right, it's a bit special!
Jccwu wrote on 2024-04-25, 15:34:part.2
Is that trackball actually wireless? I see it has some radio like logo next to the ball, but also what looks like a cord? And wouldn't "WIRELESS" be written all over the box?
