Pentium PRO?
Reply 80 of 95, by Errius
Right, that figures. I need to get 100 mbps cards to stress the bus. I'm still going to install the EISA card because this is the only machine I have with that bus and I'm curious to learn how it works.
Is this too much voodoo?
Reply 81 of 95, by PC Hoarder Patrol
majestyk wrote on 2024-04-21, 17:56:
PC Hoarder Patrol wrote on 2024-04-21, 14:23:
Is it still possible to find correct VRM modules for these boards - sure I have an old Siemens board somewhere, just no processors (easyish?) or VRMs (hard?!)
At the moment you have the chance to get some really cheap, it´s article number 135001060040 on Ebay. These VXI VRMs are top quality, but they have quite tall caps. This might cause problems when the VRM socket on the mainboard is positioned in the wrong orientation - with the VRM´s component side towards the cpu cooler.
Horun wrote on 2024-04-21, 19:14:
Those are good ! The caps appear to be 20mm (TI UCC3882 datasheet) so you need nearly an inch from vrm socket slot to heatsink if orientation is toward the cpu.....
Thank, those VRMs do look like a good deal. If my memory serves (been a few years now since I've even seen the board...recall it was stripped from an old SNI Primergy server) the VRM sockets are off to the side so shouldn't foul the processor sockets. Really must find some time to hunt it down, assuming I even still have it!!
Reply 82 of 95, by eisapc
I still have a box of Compaq VRMs if shipping from germany is desirable?
I Confess beeing multi cpu addicted such as luckybob, so there was no way bypassing the PPro.
I was lucky purchasing my systems in the early 0-years when they were availiable cheap even on ebay.
Meanwhile I own 20+ dual and quad PPro systems, but just 2 single PPro ones.
As for the OP:
looking for an socket 8 board is neither worth the efford nor the money.
Simirar to socket 4 the boards are overpriced due to their rareness and so are coolers and VRMs.
Socket 8 sytems are bottlenecked as they do not feature AGP graphics and most of them use PS/2 memory.
Reply 83 of 95, by majestyk
eisapc wrote on 2024-04-23, 07:54:
But the (new) VXI VRMs I recommended for € 6.50 each aren´t exactly overpriced, I would say.
Reply 84 of 95, by rmay635703
Errius wrote on 2024-04-22, 04:46:
1GBS Ethernet still is within PCI specs
Reply 85 of 95, by AlessandroB
I've been looking for an IBM 365 (dual Pentium Pro) for years without success, it's nice to have in the collection to install NT4.
As far as the Mac is concerned, I also fully vote for a Powermac that can boot natively with both OS9 and OSX.
I would also add that even if the Powermac G5 and the Intel MacPro were once very fascinating, I find that after having all become vintage, the case of the Powermac G3/G4 is much more beautiful and original and that it has aged much better than the G5 and Intel Macpro
Reply 86 of 95, by Errius
rmay635703 wrote on 2024-04-23, 18:22:
Apparently VLB could run as fast as 1.7 Gbps. (200 MiB/s)
Reply 87 of 95, by rmay635703
Errius wrote on 2024-04-25, 03:16:
VLB 2.0 spec supported 66mhz (too bad nobody used it that I’m aware of)
Would be amusing to include some type of embedded all in one device with high speed WiFi gig Ethernet and usb 3 bridged on a vlb card.
Sadly drivers likely would need to be made from scratch to actually ping the vlb bus.
Reply 88 of 95, by Tiido
Technically it is possible for a VLB device to appear as a PCI one, by listening PCI conf mechanism accesses and responding to them as if it was a PCI device.
Reply 89 of 95, by mkarcher
Tiido wrote on 2024-04-25, 04:55:
This idea is similar to how the 3c509 can be set into EISA mode and configured using the ECU by listening to the EISA configuration mechanism, even though the card only has ISA contacts.
Reply 91 of 95, by rmay635703
dionb wrote on 2024-04-19, 15:19:
What mistake? The PPro is older than the MMX instruction set; Intel's engineers were at the top of their game back in 1995, but even they couldn't time-travel and include something developed a year later.
Moreover, it was useless and the fact all Intel CPUs introduced from 1996 onward had it doesn't in any way change that. All humans are born with an appendix but it doesn't do anything and we can live without it. MMX was touted as 'multimedia extensions' but in fact that type of SIMD operations were rare
The “mistakes “ Intel made with the ppro were strategic ones like orphaning socket 8 and not offering at least one speed grade beyond 200mhz during its relevant lifetime (overdrive was too late),
72.63 KiB
electrically there was minimal difference between signals found on socket 8 vrs 370 which was another kick in the pants to socket 8 owners when celeron released (similar to socket 4)
Another mistake was that AGP, sdram support and Intels Starfighter 740 3d video card should have been pushed out as a prosumer thing for ppro as its main advantages beyond being a fast pci slot were mostly relevant circa 1995, all were in a halfhearted place long before eventually releasing too late in the lifecycle to be relevant. -1998 way too late to matter.
130.19 KiB
Something that I long wondered having seen thousands of systems brought back sometimes for tear down/scrap or even return under an nda during my formative years hanging out at one of the major pc support and distribution companies 1997-2007 was why were Pro150/166 extremely uncommon compared to pro180/pro200. I only saw one pro133 returned under NDA.
Also interesting was that the ppro was not as egregiously expensive in single cpu form as many note (late 95 yes but prices eroded rapidly on pro180’s)
, late 1996 the local tech bought around 250x ppro 180’s with Micronics motherboards and they weren’t significantly more expensive than a top of the line standard pentium as I had an original invoice to compare that came in the pallet I bought nearly a decade later.
Reply 92 of 95, by dionb
rmay635703 wrote on 2024-04-26, 20:30:
The “mistakes “ Intel made [...]
The discussion you are quoting me from was specifically about the lack of MMX support in PPro being called a mistake, not any of the other things you are referring to.
Reply 94 of 95, by eisapc
AlessandroB wrote on 2024-04-23, 20:28:
Got one zears ago and upgraded my server 315 with it.
Still got the single CPU 315 board .
Did anybody ever try to combine one of these boards with the PCI/MCA backplane from the PC 300/700 line?
One of these backplanes popped up and I thought about creating a PPro based MCA system.
Probably the board BIOS does not support the MCA Backplane?
Reply 95 of 95, by Horun
Those price projections from Byte are wrong but release quarters are correct. I got my first P.Pro-200 256k for $675 Feb 25, 1996 and that price held until September 1996 then spiked over $1000 until Feb 1997 on new purchases then dropped back to $650 ish. The P.pro-180 also spiked near double during that same time but the Pentium line did not because the p.pro fab line had yield issues along with very high demand for servers and workstations during fall and winter of 1996.
The Pentium 166 and then 200 were within 80% of P.Pro prices at that time except never really increased or doubled for that near six months like the P.Pro upper cpu's did. A Very interesting time !
