First post, by JF_Sebastian
Hello everyone,
I'm totally happy because I got another Socket 7 motherboard with the great HX chipset today. A good friend of mine gave me a SOYO SY-5TS5 - everything works perfectly.
I noticed that the board has an S3-Trio64V+ on it, but unfortunately my friend no longer has the correct IO/VGA connector.
Does anyone know the motherboard and have information about the pinout of the connector? I would be very happy for any help!
Kind regards and many thanks in advance 😉
Boot Up or Shut Up!
________________________
Asus P/I-P55T2P4 Rev. 3.10
Asus USB/MIR Rev. 1.11
AMD-K6-III/450AFX @6x83MHz; 2.4V
4x128MB EDO RAM 60ns
MATROX Mystique MGA-1064SG-D 4MB
Diamond Monster 2 8MB
DELOCK 91620 - CF to IDE
Reply 1 of 8, by PC@LIVE
I checked the manual, and I think it's a rather particular card, the one you're missing.
I photographed you, the pages where there is the description, I don't know if it can be useful to you in some way, but perhaps it is possible to see which VGA pins go to the connector, however I don't think it will be easy to understand something about it, without the help of someone who understands enough.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 2 of 8, by weedeewee
multimeter in continuity mode and datasheet for s3trio64v+ page 17, pin 150 vsync, 149 hsync, 168 red, 171 green, 172 blue.
no idea what the other vga pins are on the s3 chip.
http://www.bitsavers.org/components/s3/DB018- … rator_Jul95.pdf
edit: oh yeah and needle tip probes 😀
Do not ask Why !
Reply 3 of 8, by JF_Sebastian
PC@LIVE wrote on 2024-04-25, 19:52:
Thanks for your reply. I found that document, too but unfortunately there are no information about the pinout 😉
Boot Up or Shut Up!
Reply 4 of 8, by JF_Sebastian
weedeewee wrote on 2024-04-25, 20:06:
multimeter in continuity mode and datasheet for s3trio64v+ page 17, pin 150 vsync, 149 hsync, 168 red, 171 green, 172 blue. no i […]
Jipp, thats my plan now. I will share my results next few days.
Anybody out there who has knowledge about what is needed to the circuit between vga connector and the GPU? Maybe parts for decoupling or coupling to ground of the connector pins?
Best regards 😉
Boot Up or Shut Up!
Reply 5 of 8, by jmarsh
JF_Sebastian wrote on 2024-04-25, 22:35:
They should be connected directly to the GPU with 75 ohm resistors to GND for the R, G, B lines. Not sure what impedance the HSYNC and VSYNC lines use.
Reply 6 of 8, by PC Hoarder Patrol
Not that it helps much, but this is about the best pic I could find of the breakout card (seems to differ from the manual where not all the ports are hardwired). From the traces it looks like the (approx) inner 16 pins on the m/b connector are for vga.
There are a few posts elsewhere from the late 90s asking the same pinout question - none got an answer (seems Soyo were no help at all!)
Reply 7 of 8, by JF_Sebastian
Thanks to all your replies an helpful information! I'll let you know as soon as progress is made 😉
Boot Up or Shut Up!
Reply 8 of 8, by JF_Sebastian
Hey folks,
yesterday I unpacked my test probes and measuring equipment to examine the signal lines and well, here is the pin assignment of the connector for the breakout board.
Now I want to design a compatible board with both COM ports and VGA as well as a PS2 port. So far so good, but I looked at the posted picture of the original card and noticed some components in the lines of the lower COM ports. Anyone have any ideas what these could be - ferrite beads perhaps? Normally no additional components are needed between the ports and the IO-coupler ic.
I plan to put the typical 75 ohm to GND and ferrite beads with 70 ohm@100 MHz in the analog lines of the VGA port. The DDC2 lines will be looped through to the port. Further ideas for improvements are welcome 😉
I would be very happy to receive ideas and suggestions!
Boot Up or Shut Up!
