I found the exact same motherboard, that I had in a core 2 duo build I was doing, but my original board was not working. This one works, so I finished the build.
I installed Windows 7 becasue I had a copy lying around
So I dont think I have much use of this build. I picked up the case and motherboard months ago, from a thrift store, I just really liked the case.
I swapped out the IDE DVD drive for SATA, same with the HDD.
I added a GeForce 9500GT 1 GB , but might swap it out for another card.
CPU is core 2 duo 2.8 GHz
I'm going to remove the remaining IDE DVD rom (which isnt connected) and just put in a slot cover.
When I play games from this era, I just use my modern rig. Does anyone use a machine like this?
