First post, by RockstarRunner
I recently acquired a PC with an ASUS P2B-B Rev 1.01 running a P2 350.
The board revision is 1.01 which officially supports processors requiring a minimum of 1.8V, so basically no Coppermine CPUs.
ASUS made a Rev. 1.02 of this board that does support 100mhz fsb Coppermine processors, so I was interested in what were the differences, and would it be possible to somehow mod the older revision board in a similar manner.
After some digging around the net, I found this link, where it mentions you can potentially swap the voltage regulator chip, and along with the latest bios, you should be good to go:
https://web.archive.org/web/20150322010811/ht … pgrade_faq.html
I also found another post of someone actually trying this:
https://diarywind-com.translate.goog/blog/e/a … B&_x_tr_pto=nui
The Rev. 1.01 board has an Intersil HIP6019CB PWM controller, and the Rev. 1.02 has an Intersil HIP6019BCB PWM Controller.
I looked around on eBay and managed to find a Chinese seller that claimed to have the chip, it was cheap, so I took a chance and ordered it
The chip eventually turned up, and I took it to my friend who is good with electronics, and he said it's difficult to check the functions of the chip out-of-circuit, so he did couple of basic tests, then we just had to give it a shot and hope nothing smoked.
70.17 KiB
HIP6019BCB
Installation:
285.7 KiB
ASUS P2B-B Rev 1.01
299.98 KiB
Removing HIP6019CB
397.97 KiB
Chip removed
417.64 KiB
HIP6019BCB installed
Reply 1 of 10, by RockstarRunner
First test done with no cpu, ram or anything else connected, no pops or smoke, so far so good.
Next we added the P2 back to the system, along with some ram, the machine posted as normal, and the bios reported a VCore of 2.0V (this is correct for the P2 350).
Then came the big test, swapping out the P2 for a P3 850 Coppermine SL43F https://www.cpu-world.com/sspec/SL/SL43F.html
170.06 KiB
POST
299.55 KiB
BIOS P3
The machine posted, reported the CPU correctly, and the BIOS showed a VCore of 1.6V
I put the system through a series of tests in windows, and it performed perfectly. Result!
Reply 5 of 10, by RockstarRunner
Update!
After doing the above mod allowed me to run Coppermine processors, I then started looking into Tualatin adapters.
I picked up a Slotket adapter off eBay, one which supports Coppermine CPU's (important, most just support the old Celerons)
353.99 KiB
Then I purchased a 1.4Ghz Tualatin Celeron (100mhz fsb) with built-in coppermine adapter from a eBay seller in South Korea (well known to these forums I believe)
218.88 KiB
339.3 KiB
The Tualeron runs with a 1.5V V-Core, which the new voltage regulator will happily supply.
The bios recognizes the CPU, but does issue a warning that the CPU is pulling only 1.5V, but this can be ignored, as I think it's just the BIOS not expecting such low voltage CPU.
Everything is working fine, and I'm happy this board is now even more flexible.
Reply 6 of 10, by rasz_pl
So I looked it up and Im confused. Original Tualatin mod required joining 2 pins together and isolating 3 pins from the board. Did you have to cut CPU pins/did it come with pins pre-cut?
Reply 7 of 10, by RockstarRunner
Adapter (like a thin PCB that fits under the CPU) came pre fitted, so I didn't have to do anything than put the CPU in the slotket. I believe he cuts those pins when he installs the adapter.
Reply 8 of 10, by rolierop
Will this mod also work on the Asus P2B-F board?
LuckyStar 486E C2 | Intel 486DX4 100 WB | PicoGus
MSI MS-5168 | Intel Pentium 233 MMX | Sound Blaster Live
Asus P2B-F|Intel Pentium III 550 | Yamaha Audician 32 + Dreamblaster
MSI P35 Platinum | Intel Core2Duo E8600 | Sound Blaster Audigy 2 Value
Reply 9 of 10, by RockstarRunner
Check this, you may already have the newer chip, depends on revision. That said, if you have the older chip, you should be able to swap it, it's pin compatible, and some revisions do have the chip.
Re: Asus P2B-F Slot 1 Retro PC
Reply 10 of 10, by rolierop
RockstarRunner wrote on 2024-05-03, 18:49:
Thanks! I will let you know.
