First post, by kotel
- Member
Hi
I recently got this HP D530 SFF pc. After replacing 4 1000uf caps and checking the psu, i decided to turn it on. Was greeted with an screeching noise when turned on from mobo and 3 red LED blinks, followed by 4 red LED blinks, then 4 blinks forever. No beeps. Any ideas?
EDIT: I forgot to add that the board is still somewhat covered in fire extinguisher dust. Might that be the issue?
"Driving a tank is like a box of chocolates. You never know when you blow up"
- Someone from a tank game
