Reply 20 of 27, by kixs
- l33t
What's so special about this FTP?
It's just another site with lots of files. I download and merge from all sorts of sites 😀
I have never had the supposed built in FTP in Win10/11 actually work. It always gives errors. Good old Filezilla will work no problem.
The command-line FTP client provided with Windows still lacks passive mode, which makes it pretty much useless.
Grzyb wrote on 2024-05-15, 21:55:The command-line FTP client provided with Windows still lacks passive mode, which makes it pretty much useless.
And the port is harcoded to 21 as well. It's beyond useless.
I've been using the CoffeeCup Free FTP https://www.coffeecup.com/freestuff/ ... I can tolerate it... IDK depends what you're used to, seems as good as the win3x trumpet ones from back in the day.
kingcake wrote on 2024-05-15, 21:06:I have never had the supposed built in FTP in Win10/11 actually work. It always gives errors. Good old Filezilla will work no problem.
Except it's not working. Everything is failing to see that IP at all or even get DNS for it on my home network.
HP OmniBook 600CT
i486/DX4-75 | 16 MB RAM
800x600 full-colour LCD
256 MB CF card in a PCMCIA adapter
One thing that happens is that one IP can have 50 hosts on it, and one or two of them are porn or nastier, then ISPs and some nations will block them and the IP. Or family safe features in some routers, or by deliberate choice of DNS provider do.
