Reply 27600 of 27790, by PC Hoarder Patrol
- l33t
BigDave wrote on 2024-05-20, 07:33:gerry wrote on 2024-05-14, 20:02:they are the best plugs it seems https://www.youtube.com/watch?v=UEfP1OKKz_Q :) […]
BigDave wrote on 2024-05-14, 17:15:In the UK at least, it doesn't help that most plugs sold now, are usually only found with 13amp fuses fitted. I sold consumer electronics in the 80s/90s, initially retail, and back then, most equipment didn't come with a fitted plug, so as part of the sales process we'd also fit the correct fused plug for the customer, if nothing else to stop them blowing themselves up when they got home! I'm always amazed when I've bought vintage equipment from the pre-fitted plug days, at how badly some people wired their plugs (A recent Amstrad computer purchase as an example), so always the first thing I check before getting it anywhere near a socket. Then again, I guess most people were never taught how, and certainly a great many then, and probably now, didn't realise that you could even get fuses other than 13amp.
Ignorance is bliss, except where electricity is concerned, it needs respect.they are the best plugs it seems
😀...OK, I'm done with plugs, promise.... unless anyone remembers those 80's mini 3 pin plug systems made by Masterplug?
You mean the rubber PermaPlug inline connectors 😀 ...if so I certainly do, and still have a few in use scattered around the house - even used them outside on occasions and never had a problem (yet!). Then again, as I displayed an interest from an early age, my late father showed me the proper basics of wiring and all things electrical around the house.
