First post, by PowerPie5000
- Oldbie
I have just recently noticed my 2.66ghz P4 Northwood processor has been running on 1.6V... is this healthy?? It fluctuates between 1.58V and 1.64v! I have looked in the Bios on my Asrock P4i65GV motherboard and cannot find any options to change the CPU core voltage 😖
I have been doing a bit of research and it seems my processor should run at 1.475V to 1.525V... could this be a PSU or motherboard problem?
My PSU voltage readings are:
+3.3V = 3.403V
+5V = 5.283V
+12V = 12.380V
CPU Vcore = anything between 1.580V and 1.645V when it should be no more than 1.525V. (Pentium 4 2.66ghz SL6PE) does anyone have any suggestions as to what is going wrong? cheers
