Questions about a CMS-401 MIDI card
First post, by Old Thrashbarg
I snagged a CMS-401 MPU card for cheap off eBay a couple weeks ago, and since I now have a Roland MT-100 on the way (also acquired for cheap 😁 ), I figure it's about time I look into setting this card up.
Here's the problem, though... my card is almost identical to the ones I've seen discussed various places online, except for one detail: mine does not have the address and IRQ jumper headers populated. Instead, it just has the empty pads, and traces hardwired to particular settings.
Here's what I mean:
(I've mentioned before, but I'll say it again: I hate my POS camera. That's the clearest picture I could get out of it, and even that took a dozen tries. 😠 ) Anyhow...
The IRQ setting seems fine the way it is... it looks to be wired for IRQ 2/9. What's throwing me off, though, is the address setting. What little documentation I can find about the card indicates that setting is gives an address of 3e0h, which is rather strange.
I know at least a couple people on here own (or have owned) one of these cards, I've seen 'em mentioned here before, so I'd like to ask for some confirmation here... to set it to the standard 330h address, I need to bridge positions 2 and 3, right? What about position 0... on the cards with the header pins installed, is that one shorted even without a jumper on it, or do I need to cut that trace?
Reply 1 of 26, by Amigaz
I own one of these which I use in a 386 machine I'm going to dig out this weekend during my wild photo shoot for the retro rig photo thread we have going here.
How can I help?
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 2 of 26, by Old Thrashbarg
Well, I'm mainly looking for two things... the first is, whether the trace connecting the two pins at position 0 of the address selection exists on other cards... basically, if you could prod those pins on your card with a multimeter, and see if there's continuity between them without a jumper installed there. I think that trace probably needs to be cut on mine, but I want to make sure before I do it.
Second, would be a verification if the information I found about the jumper settings is correct, that putting jumpers at positions 2 and 3 on the address selection is actually the correct setting for the 330h address. That's something I could find out by trial-and-error, I suppose, but rather than installing full pin headers I'm planning on just soldering in a couple little wire bridges at the necessary positions, so knowing exactly where I need to install those bridges would save me some trouble.
Reply 3 of 26, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Just plug it in and figure out where the I/O is located before you go through that hassle?
1+1=10
Reply 5 of 26, by Amigaz
Mau1wurf1977 wrote:
Try "Gateway" from Legend Entertainment. If it works, you have a 100% compatible MPU401 card...
I can confirm it's 100% compatible with the Roland MPU-401 spec
Reply 6 of 26, by Amigaz
Hopefully I can answer this shortly, just got back from a 4 km "morning walk"
Reply 7 of 26, by Amigaz
Ok, just checked my card.
The pins at "0" gives no continuity
My card is set to port 330 and IRQ = Jumper on "0" and jumper on "2" at
Reply 9 of 26, by Old Thrashbarg
Huh, so I guess the documentation I found was wrong (thanks for nothing, usenet! 😒 ), and I don't actually need to change anything.
I guess I could've just plugged it in and found that out on my own, but not knowing the history of my particular card (and noting that there are some scratched traces and other slight damage to it), it's nice to have assurance of how it's supposed to work, so that I can easily tell whether it works at all.
So, thanks a bunch for your efforts, Amigaz, I do appreciate it. 😀
Reply 11 of 26, by Mr_Blastman
Digging up an _OLD_ thread...
I found one of these CMS 401's for sale but, alas, from the pictures it looks like someone took all the chips out? (or most of them):
Does it look useless or is there hope? (no vultures please)[/img]
Reply 12 of 26, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The important special chip is there, it should be possible to replace the others, they are not very uncommon.
Mouser (I am not familiar with component dealers overseas, this is the first I thought of) should have everything except the SRAM. It is available at Ebay (you can even look for a HM6116 or others instead).
On the other side there may be a reason why it was cannibalized...
1+1=10
Reply 13 of 26, by Mr_Blastman
Seems more trouble than it is worth for 50 bucks initial investment.
Reply 14 of 26, by Robin4
You are also missing the address and the IRQ jumpers..
Reply 15 of 26, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
They may be hardwired
1+1=10
Reply 16 of 26, by a.d.i
first post, so hello to everybody 😀
i have this card but missing cables for it 🙁
can somebody send me picture of inside of db25 connector?
in order to build my own cable i need to know if there are any parts inside this connector and which pins are connected to midi out
Reply 17 of 26, by vetz
A CMS 401 card for sale here with $25 buy-out:
http://www.ebay.com/itm/Roland-CMS-401-Interf … =item416cc849ff
I bought a Midiman MM-401 card from the same seller, so thought this might be interesting for some in here who are looking for a intelligent mode compatible MPU-401 card.
Reply 18 of 26, by cricket
I also have a board that has no cable and it also doesn't get detected.
Any chance to get the pinout of the cable?
Reply 19 of 26, by cyclone3d
cricket wrote on 2020-06-24, 19:59:
I've got one of these cards on the way... One of the few MPU-401 clones I didn't already have. I'll post the pinout once it arrives
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
