Creative CD ROM Query
First post, by CU_AMiGA
Hi
I have a PC rig setup inside my Amiga 4000 via SBC. It is a PentiumMMX 233mhz. I also have a ATI Mach64, Soundblaster 16, and a 3DO Blaster. All on the ISA architecture. I have DOS and Win3.11 installed, and a Creative CD ROM attached to the 3DO Blaster. The problem i have is that upon DOS bootup, sometimes the CD ROM drive will freeze (not respond). It seem ok when i first switch the machine on but its when it looks for the CD ROM drivers that it happens (after the HIMEM sequence). When it happens the CD ROM drive draw wont even open or shut. Other times when i boot the machine up it will work ok and reads cd's fine. It just sometimes on bootup it does this and freezes (it does occasionally "unlock" itself and runs fine from there on).
I have tried cleaning the ISA card contacts, including the RAM stick. I have also changed IDE cable, but no luck there either. I am really running out of ideas on what i can do. I hope nothing is not working anymore. Has anyone got any ideas?!
Thanks for your time. 😀
Reply 2 of 22, by Jorpho
3DO Blaster? That's a pretty exotic configuration you have thar. If I'm not mistaken, that works with one and only one specific model of Creative CD-ROM drive; are you sure you have the right one?
If I understand you correctly, the CD tray not opening or closing suggests that if it's not a power supply issue, the drive itself is mechanically failing. Try a different connector on the power supply, or try replacing the power supply completely.
Reply 3 of 22, by CU_AMiGA
Tetrium wrote:
Think it could be something to do with either normal CD's or burned ones?
There is no cd in at all. Either way that makes no difference
Reply 4 of 22, by CU_AMiGA
Its definately the right one buddy cos when its going it works well. I am not too sure whether its a mechanical issue or not. As before it boots up DOS, the cd rom drive appears to be working fine ie it ejects and closes. But sometimes it freezes when DOS loads up the cd rom drivers. As for the power supply it is a new old stock one. It is a 300w one and slightly more powerful than the previous one. I had this trouble initially with the older power supply but somehow managed to sort it out! I could check the power connecters I guess
Reply 5 of 22, by Jorpho
Except sometimes it doesn't. 😉
The other thing that might be worth checking is if the drive works when it's connected directly to an appropriate motherboard rather than to the 3DO Blaster or some other controller card.
Reply 6 of 22, by CU_AMiGA
I think creative cd rom drives only work on creative products dont they? Or would it work if I plugged it in the ide slot on the sbc? I have no spare motherboard
Reply 7 of 22, by swaaye
The drive is a Matsushita CR-563, right? It uses the Panasonic/Matsushita interface. So you'd need a sound card or interface card with that and the driver to go with it.
Reply 8 of 22, by CU_AMiGA
Correct. So I can use it with either the 3do blaster or the soundblaster 16
Reply 9 of 22, by swaaye
Make sure it's a SB16 with that Panasonic CD interface. There are a variety of SB16s.
Reply 10 of 22, by CU_AMiGA
yeah the one i have installed has the interface. but i didnt bother using (testing) on that as i have it connected to the 3do blaster (in order for it to be usable with the 3do).
Reply 11 of 22, by CU_AMiGA
nope that didnt work either! anyone else got any ideas?
ps i think i put this thread in the wrong place can the mods please move it?!
cheers
Reply 12 of 22, by swaaye
Watch for another CR-563 to show up on ebay? 😀
-moved to Marvin
Reply 13 of 22, by CU_AMiGA
Hi
update here. i have tried a higher powered psu and i have tried a different cd rom drive (same model). and still the same results. i have also connected the cd rom drive to the soundblaster card only and it seems to work fine (although i might test for longer). i dont know what to do here and its not looking good. the only other thing i could try is another soundblaster card.
regards
Reply 14 of 22, by TheMAN
what version of drivers are you using?
Reply 15 of 22, by CU_AMiGA
hi
i am not quite sure which version it is but heres the link to the version i got:
http://www.mediafire.com/file/60o08qxsegzsx49/cr563b.zip
i have also tried connecting a different soundcard and graphics card (to rule that out) and still same results. i might have a go at reinstalling the whole of the cd drivers software. anyone got anymore suggestions?
regards
Reply 16 of 22, by TheMAN
holy shit that is ancient!
the version number is displayed when the driver loads during boot
you need to get a newer version... that driver is too old and buggy
go download SBCDW95.EXE from here:
http://ftp.isu.edu.tw/pub/Hardware/CreativeLa … om/sbcddw95.exe
it is version 4.22 and is the latest one
Reply 17 of 22, by CU_AMiGA
i will give the above a try but it looks like it is for win 95 (i have win 3.11 installed). also it says i have ver 4.22 on bootup! 🤣
Reply 18 of 22, by TheMAN
it's for both!
read the readme file
Reply 19 of 22, by CU_AMiGA
ah! yes i ve now seen it! i tried installing it but it froze when it was "analysing" the autoexec file! i think i may need to unintsall the whole cd software lot and start again! 🤣 i guess i can do this by manually deleting old files and using the old autoexec file?! regards
