Reply 20 of 49, by Totempole
- Member
ProfessorProfessorson wrote:
AMD still offers the Rage 128 drivers, though I want to mention I have had some issues with the installer not detecting the card and canceling the install depending on who made the Rage 128 exactly. If this happens to you, you can unrar the drivers into a folder and do a manual install in Win 98 from the device manager area, pointing to the folder with the drivers. It will present you with a list of files, and you need to select the top win9x related one, then select the card from the list of Rage 128 powered cards that it will present you with. For normal Rage 128 Pro cards I believe you will want to select the Rage Fury Pro from the list. The card will then install fully, including its ATI control panel options for DX and OpenGl.
Thanks will keep this in mind. I think they're just OEM Rage 128 Pro's, so the
Rage Fury Pro Drivers should work.
