Reply 1800 of 58438, by Mau1wurf1977
Markk wrote:
Finally my card arrived, and not only the disk I connected to it was bootable, but it was visible on dos 6.22. The chip on the card is a Silicon Image 3114, and I'm sure it has it's own bios, that's why it's bootable.
Hmm that's the chip on my card!
I can get into the RAID Bios by pressing F4. Here you can build Raid arrays. Here I can also see any SATA device connected, like a DVD drive or HDD. But I couldn't get it to Boot. I admit I didn't play around much longer as I have a working solution using CF cards but will test again.
vetz wrote:
Here is the SI 3114 card, 14 dollars shipped worldwide new:
http://www.ebay.com/itm/4-SATA-S-ATA-Port-RAI … =item2556a904ec
Do not buy the VIA S-ATA card. I just got it and you can't boot from it. Seems to have issues with the Win98 drivers as well.
Ok thanks. And you have this one? And it boots?
sliderider wrote:
There is one company that still makes them and their main customer is the government because a lot of government departments still run on old tech.
http://athana.com/
They also still make 8" floppies, tape backup cartridges, and tape on reels.
That's amazing. I have such good memories of these floppies 😀
My YouTube channel
Reply 1801 of 58438, by Markk
I admit that's weird. My card is the same. I have installed it on my Pentium III pc (QDI Advance 10F motherboard) and it boots fine. And I don't remember setting the BIOS option to boot from a SCSI device.
Reply 1802 of 58438, by vetz
[/quote]
I have the VIA card, but I've ordered the Silicon Image as well. So far no luck with the VIA. Can't even see the disk in DOS, no bootup screen and when installing the Win98 driver the computer crashes. I will have to test some more though before I give a final verdict.
Reply 1804 of 58438, by subhuman@xgtx
Bought a brand new AAlchemy 8164 + Power supply, will post pics as soon as it arrives 😜
Reply 1805 of 58438, by sliderider
vetz wrote:
https://dl.dropbox.com/u/57506833/vogons/diverse/powerleap.JPG […]
Powerleap PL-iP3 with 1.4ghz P3 😀
I hope you have a 133mhz bus machine to put it in. I had a problem when I first got my 2 and tried putting them in 100mhz bus systems and they did not report the speed correctly or run at anywhere near 1.4ghz. I had to pull the PIII's out and replace them with Tualerons to get them to work at 1.4ghz.
Reply 1806 of 58438, by sliderider
It must be nice to be rich. 😜
Reply 1807 of 58438, by vetz
Already got a pin modified P3 for my 440BX system. Bought this since it was cheap and I have a Asus P2B laying around that could use it in the future. As far as I know it supports 133mhz FSB. If not, it's easy to replace the CPU.
Reply 1808 of 58438, by shamino
Later 440BX's are pretty easy to run at 133. It's the best way to run them IMO, even if Intel doesn't approve.
P2B rev1.02-1.04 usually can't handle it, but rev1.10-1.12 usually run 133+ reliably. I think some of the boards have the wrong 133 jumpers indicated, resulting in the wrong PCI divider, but I don't remember which. The datasheet for the clock generator clears that up.
I'd love one of those Tualatin adapters. In the mid-2000s I saw one at a local shop for $15 - and passed on it. Stupid.
Reply 1809 of 58438, by memsys
My latest haul
Sound Blaster Pro 2 CT1600 ISA
Sound Blaster Vibra 16S CT2800 ISA
Sound Blaster AWE32 CT3900 ISA
Sound Blaster AWE32 CT3980 ISA
Sound Blaster 32 PnP CT3670 ISA (the clips that hold the RAM down are broken sadly)
Diamond 3D DT297A40 ISA
Total cost €26,75 including shipping.
Reply 1810 of 58438, by Artex
Some recent acquisitions!
Guillemot Maxi Gamer Xentor 32 (NVIDIA RIVA TNT2 Ultra) AGP 32MB (1999)
ATI Radeon 9700 Pro 128MB AGP (R300) (2002)
Diamond Stealth 3D 2000 4MB PCI (1996)
Gravis Ultrasound (Classic) Rev. 3.4 ISA (1993)
Gravis GamePad (Boxed) (1992)
Reply 1811 of 58438, by subhuman@xgtx
nah, I just keep myself from travelling too far away on vacation 😀
and I wanted this damn card so much because of 8xFSAA even if I'm limited to glide3 & opengl 😜
Reply 1812 of 58438, by s3freak
I bought a real S3 Trio 64V2/DX 2MB via eBay so that I can have a real one as well as an emulated one. DOS apps work great on it but in Windows 7, you are stuck with 640x480 and 800x600 in 16 colours, yes SIXTEEN colours due to the lack of Windows drivers and a VBE 2.0 driver in the BIOS. It has the older VBE 1.2 driver in it instead.
The other retro hardware that I have bought many years ago is a genuine Creative Labs Sound Blaster 16, non plug and play. I had to manually add the device in Windows XP. It is now sitting idle in my collection as that motherboard with an ISA slot (ABIT KT7) died and I no longer have ISA slots in any computer.
My 486 is my real DOSBox, as well as my customised DOSBox!
I am not very active on VOGONS, please send a private message if you need a quicker response!
Reply 1814 of 58438, by Artex
vetz wrote:
Since I love my SCSI caddy CD-ROM I just had to buy this one as well 😀
I....can't...look away!
Reply 1815 of 58438, by Mau1wurf1977
vetz wrote:
Mitsumi CRMC-LUOO5S 1x CD-ROM. Since I love my SCSI caddy CD-ROM I just had to buy this one as well 😀
Oh the memories. I had one of these when they first came out. It was the CD-ROM drive for the masses! I got mine from Escom and I remember playing the 7th guest on it although it was meant for double speed.
My recent purchase:
New and 10 bucks per drive + shipping. Wondering how long they will keep making them and if we get a warning period to buy more 😀
My YouTube channel
Reply 1816 of 58438, by nforce4max
Tyan Thunder K7Xpro with 2x MP 2600 and 3gb ram with matching coolers $35
2X HP Pavilion tx2510us $85
A P4m Sony Vio for $10 (like new condition)
Reply 1817 of 58438, by bytesaber
That's one mighty fine cup holder! Nice find.
Reply 1818 of 58438, by Stull
Does it make waffles too?!
Reply 1819 of 58438, by Malik
Mau1wurf1977 wrote:
My recent purchase: […]
My recent purchase:
I took out the plastic bezels and sprayed all beige before replacing them in my "classic" PCs. 😀
