First post, by i486_inside
- Member
I have a 486 build with what i believe is a MB-4DUVC MODEL 1 motherboard, i have tried several floppy drives in it and two floppy controllers, and it still won't boot or read floppies, Does anybody out there know what the problem may be.
I know the cable isn't on backwards.
The drives always blink and make normal floppy drive clicking noises, but the the computer gives back "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER", and when i booted a hardrive that had dos on it, the computer would fail to read the disk also.
