Reply 2720 of 58436, by awergh
wrote:wrote:I thought about taking just the bits I wanted and leaving the AT case behind
As hard as it's getting to find AT cases and you were going to let one go the crusher? Shame on you! 😠
wrote:Wow now that is a waste to let an AT case go to the dump/scrappers, you will regret that later once you have a need for an AT case. They are hard to get as it is while the boards are easy but the cases and power supplies are not.
I knew someone would make me feel bad for what I've left behind in the past. Well I already felt somewhat bad partly because I was sure I wouldn't need it at the time but anyway more recently it is just a lot of effort to take home I guess. Mainly because I have to take it on the bus home which is alot more effort then just taking components because I don't have to carry anything. I know it is kindof sacrilige to leave stuff to die like that and I do feel bad but in the recent case it was that there were two cases so I took the one that was easier to take home. I probably could of grabbed the case the next day.... but I think it was bent out of shape at that point with other stuff on top of it and I kindof think there is a limit to how many cases I can have before someone complains that I might have a few too many.
That is basically my thoughts yesterday but ultimately grabbed it anyway, not that I didn't like the case or didn't want it, just that it was a problem of space and only being able to grab so much. Its more a problem in winter when the sun comes in so I can't just have the middle of my bedroom full of computers because I'd rather leave them out of the sun.
I hope you don't stay angry and disppointed with me forever 🙁 🙁
PS: I'm sure I'll regret it at some point just like whenever I leave/chuck out anything and realise I should of kept/got whatever it is but such is life I guess
