First post, by badmojo
- l33t
I have a revision 2.1 version of a VL/I-486SV2GX4 Motherboard, which includes multiple options for CPU voltage - see the spec below for details. The board came with a DX266 Overdrive chip on it and it all works fine, but the relevant jumpers (32 and 33) are set to the 3.45 volt setting. How can that be? Is the spec wrong, or will a 5 volt chip just draw as much as it needs regardless?
Also, the spec doesn't include a 5 volt option - it only goes up to 4 volt. Does that also indicate that the spec is wrong?
http://www.motherboards.org/files/manuals/1/C … I-486SV2GX4.htm
