Need Help Selecting an AT Power Supply
First post, by boxpressed
I recently received a mixed lot of 386 and 486 motherboards (pics to come in another thread) that I'd like to test and run through their paces. However, I have neither an AT case nor an AT power supply. I figured that I could still test with a power supply only. I was a little surprised that you can still buy new AT power supplies. I have a few questions about them for more experienced members.
* Do all AT power supplies have the same connectors and pinouts?
* How much power do I need? CPUs on the boards range from a 386-40 to a 486DX4-100.
* Black wires should be adjacent to each other when plugging in both connectors, correct?
Finally, can anyone point me to a high-quality, reliable unit? Thanks in advance!
Reply 1 of 26, by bjt
If you can source an AT power supply at reasonable cost, great, otherwise a new ATX supply with an AT-ATX conversion cable is a good option.
Any new power supply you can buy these days should be sufficient for a 486. However not all PSUs are created equal. More info here: A tale of two PSUs
Reply 2 of 26, by AlphaWing
I agree, I use a such an adapter ATX-AT cable on my Packardbell P-120, the only fully AT style power connector computer I have left, had to replace its powersup last year.
Its hard finding an AT-Powersupply that is quality, with atx ones you just need to make sure you find one that still outputs -5v.
Which isn't really that hard.
Reply 4 of 26, by MaxWar
Seriously how do you find quality/new ATX PSU with -5v nowadays? I can't find them anywhere.
I happen to need one :p
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 5 of 26, by AlphaWing
New Old stock on Amazon mostly for me. If you look carefully there are more then a few sellers still in possession of older sups that have just sat in there boxes, being sold on there.
Heres an example, but the seller has jacked his price up since when I bought my last one from him... at 20$ 🤣.
Unbelievable he wants 70$ now 🙁
http://www.amazon.com/gp/product/B00BPXJYXU/r … 0?ie=UTF8&psc=1
Its a good PSU but not worth that 🤣.
Just try doing searches for ATX 1.3, FSP, forton, etc.
Reply 6 of 26, by ibm5155
EDIT: wrong thread :v
Reply 7 of 26, by MaxWar
AlphaWing wrote:
New Old stock on Amazon mostly for me. If you look carefully there are more then a few sellers still in possession of older sups […]
It is different here in Canada. Most of those Amazon sellers, including the one you linked, won't ship to Canada. So we do not have access to a large part of the New old stock.
In any case finding these things is tedious work. You have to look at specsheets of PSUs to know if they have -5V and often they are not put in evidence.
Another technique would be to have a list and search for specific models. I just tried with the one you linked and could not find anything elsewhere in Canada.
Edit: I managed to find those but that is a funny brand.
http://www.newegg.ca/Product/Product.aspx?Ite … N82E16817182006
Reply 8 of 26, by AlphaWing
Thats interesting, I had no idea Amazon, sellers don't ship to Canada.
But, yea like you said when searching I'd find a model then look up its info, on Google.
Reply 10 of 26, by jwt27
You can easily add a -5V rail on any PSU using a linear power regulator (7905 for example) or DC-DC converter 😀
Reply 12 of 26, by MaxWar
Good Idea, I guess this is what we will have to do in the future too.
I was also starting to consider Arcade power supplies. But those I see would not be powerfull enough I think
They are typically 16A@5v, 4A@12V, 1A@-5V
Mostly weak on the 12V I think,
http://www.ebay.ca/itm/15A-Arcade-Switching-P … =item4cf793ca23
Reply 13 of 26, by Mad-Lunatic
I picked up one of these recently (ATX 20 PIN to AT P8/P9 Converter with -5V & On/Off Switch & Dummy Load) to use with a non -5V capable ATX PSU - seems to do the trick quite well!
http://homenet.gnu-linux.net/ -- My computer collection, past and present
Reply 14 of 26, by brostenen
That is some nice piece of converter-kit. 😀
Reply 15 of 26, by Stiletto
Where is it getting the -5V from?
do the Fandango!" - Queen
Stiletto
Reply 16 of 26, by smeezekitty
Presumably a DC to DC converter
Reply 17 of 26, by boxpressed
Thanks to everyone for the great suggestions, but this solution may work the best for me. I have a new ATX PS without a -5v rail that's just collecting dust. I just bought one of these and will report back once I've had a chance to test.
Reply 18 of 26, by AlphaWing
Yea thats an interesting cable\Idea!
Reply 19 of 26, by MaxWar
Yeah I am tempted to get one of them too, but I will wait a bit. Looking forward to hear about your experience with it.
