Reply 5700 of 53299, by dogchainx
- Member
wrote:wrote:I use this stuff with either direct sunlight or black lights and it works a treat! I just kinda 'paint' it on the plastic parts and let them sit there for 2-3 hours. I had to go to a beauty supply store though because no other places carry this stuff with the high concentration % of peroxide. Use gloves and wear eyewear - it will burn!
I've used cream peroxide too but I tend to get some streaking/'brush stroke' effect which is quite noticeable after rinsing and drying. Has that happened to you?
I work in a chemistry lab...I'm going to try out a few of my own concoctions. Instead of xanthan gum, using hydroxyethylcellulose (easier to clean up). instead of hydrogen peroxide, a high concentration of carbamide peroxide with propylene glycol instead of glycerin. Peroxides activate with UV, water, and heat, so I'll try a black light. No heat, since that could warp some plastic parts.
Carbamide peroxide should be safer to work with, though a slightly longer application time is needed. It also comes in a granular form, so initial mixture would be more like a paste until it dissolves in the propylene glycol.
Also, I got in a Pro Audio Spectrum Plus card and 386DX-40Mhz motherboard with math-co-processor. OH...and got 24 3.6v Tadarin batteries for $22 shipped. 24 of them! woot1
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
