First post, by tokyoracer
- Member
Hi chaps.
I am having issues with a motherboard I aquired some months back (maybe a year now or so). It's a Gigabyte BX-2000 board with a rather handy "DuelBIOS" feature. Both had an older version on the chips that didnt allow Hard drives much above 20GB to be read but I tried installing two 80GB drives and it just hangs when posting (when it searches for them in the IDE). I can manually feed the BIOS the sectors, cylinders, and other bits but it will only address 8GB that way.
I did some research and found the latest BIOS update fixed this issue allowing 120GB and beyond so I gave it a go flashing onto the secondary BIOS (just in case it goes a-skew) and success! It detected the hard drives correctly but now after it posts past the IDE detection, it just goes to a blank screen with a blinking underscore curser top left of the screen and sits there.
I wonder if I might have a jumper set incorrectly or something but I can't say for sure since I am a bit lost looking at the .PDF manual. All the old threads I found about people having hard drive issues with this motherboard all suggest the person/people "just get a PCI IDE controller card" and not really fixing the solution (words to that effect anyway). Not to mention I don't actually have a PCI slot free currently! I'm not sure where else to go from here so I am curious if any gurus here might have any idea what might be at fault when reading IDE devices correctly and ultimately, booting past the posing process, hopefully to put 98SE on it. 😀
Thanks in advance.
