ct4520 AWE64 ISA
First post, by jcarvalho
Hi guys, this is my first post on this forum, but I am following the posts here for some time, always "on the window".
I have a CT4520 that I would like to configure on a P2@450Mhz system running Windows 98 SE, but I cant find anywhere the drivers. Can some one point me a good link to download the ISO?
At the moment, my W98 cant see the card.
Thanks for any kind help,
Jorge
Reply 1 of 5, by PhilsComputerLab
Windows 98 has the drivers for the card. Meaning it should work without installing anything from a CD. If Windows can't see the card, well that's not good.
YouTube, Facebook, Website
Reply 2 of 5, by brostenen
VOGONS Driver Library
In this section there are drivers for a lot of stuff.
And yes. If Win98 can not see the card at all.
There are a big problem somewhere.
Reply 3 of 5, by HighTreason
I would suspect capacitors, as I've had two AWE64 cards do that and the capacitors turned out to be the problem.
Though sometimes just starting the machine without the card once and then re-installing said card will make the problem go away - this goes for any card.
Reply 4 of 5, by jcarvalho
Hi guys! First of all, I want to thank all the kind and fast info that provided. Dont know why, after turn off and on the computer, the card was recognized. My problem is find a suitable driver for DOS 🙁
I am searching in the link that was kindly posted brostenen, next will try to find a tutorial. This card is an headache..
Reply 5 of 5, by brostenen
Yeah... PNP is sometimes a bitch. These drivers here, are MS-DOS-6.22 only...
(not Win95 and later, just 6.22 and earlier)
Install PNP manager first. They are from Phil's website.....
http://www.philscomputerlab.com/drivers-for-awe64-gold.html
