First post, by subhuman@xgtx
- Oldbie
Hi guys. I recently got hold of a CUV4X-DLS but it seems like I f**cked up this time and I ruined the plastic cover that slides in when you lift the socket lever. Because of this, the CPU that goes in socket 0 won't fit properly anymore and I thought of replacing with one from other 370 boards that are broken. Only problem I have is that.. I'm worried to cut traces/damage the socket even further since I have no experience in doing this.
Do any of you know whether if there is a safe way to do this with a flat head screwdriver or not? I just think having to throw a dual S370 board that was otherwise working perfectly is a complete waste..
Thanks everyone.
