Reply 980 of 27788, by Caluser2000
Just been mucking around with networking in windows 3.1 in Standard Mode on the old girl. Turns out the ftp and telnet clients bundled with the tcpip32b package for wfw 3.11 appear to function just fine on it. I was expecting them to be 386ehn only applications.
Reply 981 of 27788, by mwdmeyer
I had a retro lan yesterday.
Computers ranging from Pentium 2 400MHz up to Pentium 4 2.66GHz. The majority of the machines were Pentium 3s running Windows 98, with a single Athlon 1.2GHz.
11 computers/players in total.
We played: UT, Q3A, Tribes, AOE2 and RA2.
It was great fun 😁
Reply 982 of 27788, by Darkman
tried WinNT4 on my P133/64MB machine on a spare hard drive.
It ran brilliantly, stable, fast, however it was obviously pretty limited game wise (since I couldn't find any Diamond Monster 3D drivers specifically for WINNT4 I had to use the generic 3DFX ones, not as fast as they should be), not to mention some of the Windows games this thing can run not even wanting to install.
could be useful as a dual boot with Win95 though.
Reply 983 of 27788, by Arctic
I build a new retro system 😁
Just a quick preview, I will open a separate Thread
Pentium III-S Tualatin 1400MHz
512MB (2x256MB) PC133 SDRAM 2-3-2-7
ASUS TUSL2-C
Compaq Voodoo 3 3500C AGP 16MB
Terratec Aureon 5.1 Fun
Allied Telesyn ATX-2700 PCI
CPU 28-32*C
Reply 984 of 27788, by shock__
Reworked my Disney Sound Source emulator (basically took the prototype apart and made a nicer looking one on perfboard) and confirmed it to be working with the autodetect routine of Dungeon Master (doesn't work in DOSBox due to a higher level of emulation) - also checked out that both chip variants for my circuit can be mixed.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 985 of 27788, by Darkman
just built a system out of scratch using spare parts, figured it would be a bit of a challenge.
Dell Dimension 4100 S370 motherboard (dont have the case, but I do have the PSU)
1GHz PIII Coppermine (133Mhz FSB)
512MB SDRAM
120GB IDE HDD
Radeon 9550 256Mb (budget card thats a few years newer, but an ok fit for a system like this until I decide to get something more fitting)
SBLive 5.1
Win98SE
the system wont be for personal use, more of trying to put a case Ive got to use.
Reply 986 of 27788, by badmojo
I've been meaning to master the art of de-soldering chips. Previously I've used a dremel to cut the chip off and from there it's easy to remove the legs individually, but obviously that kills the chip. A project on my C64 required a chip to be replaced, but I didn't want to destroy the original chip, so I bought myself some de-soldering braid and practiced on a dead board first, and then tackled the real thing.
With a hot, clean iron, and a well placed section of unused braid, it went very well. The solder around some pins was stubborn for whatever reason and needed some new solder added to loosen it up, but with patience the chip came out cleanly.
Reply 987 of 27788, by Robin4
Iam trying to find drivers on the almost gone years old manufacturer websites.. And trying to save what i can.. The drivers i will also upload to vogonsdrivers. Because this is the only real working resource for now.
What i really hate is the clean up on old websites what google is doing on this moment.
Reply 989 of 27788, by Skyscraper
Scali wrote:
Today I won the Oldskool demo compo at Revision 2015: http://www.pouet.net/prod.php?which=65371
Mind-blowing!
Reply 990 of 27788, by King_Corduroy
No way! You wrote that!? I just watched that on youtube yesterday and that is freaking cool as hell!
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 992 of 27788, by dogchainx
Awesome!
Some people's coding skillz on that old of equipment is just insane. 😎
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 993 of 27788, by alexanrs
Now I want to run this on an actual machine oO
Reply 994 of 27788, by 5u3
Congrats on winning the Revision oldskool compo guys! This is no small feat considering it went up against several good entries on platforms which had strong scene support for decades (C64/Amiga). It's rather hard to understand the technical implications of using a bare IBM PC with CGA.
Reply 995 of 27788, by QBiN
Very slick. Well done and congratulations!
Reply 996 of 27788, by Stiletto
Amazing job on this guys... and thanks for the VOGONS shoutouts! 😁
do the Fandango!" - Queen
Stiletto
Reply 997 of 27788, by HighTreason
Indeed, this is what the scene is supposed to be about, it's not about being pretentious and artsy... It's about throwing the instructions in the bin, writing your own before ignoring those too and coding to the point that it practically becomes an art form by itself.
Reply 998 of 27788, by ODwilly
Tonight I attempted to delid a Pentium 4 670. Word of advise, do not attempt this. The die is stuck to the IHS and WILL shatter
Reply 999 of 27788, by Murugan
Dismantled my 486 to have the RTC chip replaced/repaired. That's beyond my skill 😀
