Reply 7620 of 58436, by Zenn
That's not a fair comparison... Yours is 875P and Skyscraper asked for 865PE. 😉
Anyway I vaguely remembered seeing a Gigabyte P4 Titan 8PENXP put up for sale in the local forums a couple of years back. I wouldn't have remembered the exact model but I remembered it had 1 distinguishing feature: an add-in board which contributes to the power phases of the motherboard. Also notice the six DIMMs!
Reply 7621 of 58436, by Skyscraper
That looks like a very interesting board, I have never seen one for sale here in Sweden. I bet its very rare just like the Soltek SL-865PRO2-FGR.
The Supermicro board also looks nice even if it is a Canterwood board.
None of them look half as good as the Soltek board though and looks is also a feature 😉
Reply 7622 of 58436, by Artex
That looks like my P4 "Granite Bay" board - the Gigabyte GA-8INXP - first one to use Dual Channel DDR and has that "Dual Power System" add-in board too.
Reply 7623 of 58436, by havli
2x Xeon 5110 (Woodcrest / Conroe ; 1,6 GHz)
2x Opteron 254 (Troy / San Diego ; 2,8 GHz)
Radeon X800 GTO (R430, 256MB GDDR3)
Reply 7624 of 58436, by Skyscraper
This was posted like 5 min ago with a buyout price of ~24 Euro + 7 Euro shipping.
Its not available anymore... 😀
Reply 7625 of 58436, by oerk
Lucky!
Let us know the exact specs when you have it...
Reply 7626 of 58436, by kithylin
Yeah. Make a thread about it or something, skyscraper. And post the link here, I wanna hear about that and what it is. Looks like Pentium-MMX. But using both sdram and 72-pin ram together is weird, normally I would of thought most systems wouldn't allow that.
Reply 7627 of 58436, by Skyscraper
Its a Dual Pentium Pro board with two CPUs and some memory 😀
In the picture we can read P6NDI, Google says ADVANCED INTEGRATION RESEARCH, INC. also known as AIR which we also can read on the board 😀
I will post about the board in the Dual Pentium Pro thread later. It will be some days until it gets here.
Reply 7628 of 58436, by petro89
Got a Slot-A 750 with a Thunderbird core! Time for another old skool rig build with some Voodoo 2 SLI lovin!
*Ryzen 9 3900xt, 5700xt, Win10
*Ryzen 7 2700x, Gtx1080, Win10
*FX 9590, Vega64, Win10
*Phenom IIx6 1100T, R9 380, Win7
*QX9770, r9 270x, Win7
*FX60, hd5850, Win7
*XP2400+, ti4600, Win2k
*PPro 200 1mb, banshee, w98
*AMD 5x86, CL , DOS
Reply 7629 of 58436, by Cyrix200+
Cyrix200+ wrote:
http://i.imgur.com/u8XzYSpl.jpg […]
Turned out to be:
2x Intel PIII-S 1133
Tyan Tiger 230T (S2507T)
With damageD CPU socket where the cooler clamps, so it needs those wide clamps.
3x512MB Registered PC133 SDRAM
Asus V6800DDR TVR (not sure yet if 32MB of 64MB version)
A whole bunch of Maxtor 250GB drives
More images: http://imgur.com/a/xHRnF
1982 to 2001
Reply 7630 of 58436, by Cyrix200+
Also picked up a nice looking AT case with:
Asus SP97-V mainboard (Socket 7 SiS 5598 chipset)
LReNlJOl.jpg?1
Downside: they were used as ISDN 'servers', and all brackets for serial/parallel/USB/etc are not included 🙁 Will have to get some!
Intel Pentium 133MHz
Elsa Winner 1000/T2D-2 S3 Trio64V2/DX
Some have memory, hard drive and FDD.
I liked them and they were cheap (25 euros each) so I got four of them 😀
More images here:
http://imgur.com/a/w9hTD
1982 to 2001
Reply 7631 of 58436, by DonutKing
Zenn wrote:
That's not a fair comparison... Yours is 875P and Skyscraper asked for 865PE. :wink: […]
I knew a guy who had that board (or a similar one) with the daughter board for the power regulator.
He had no end of trouble with it and ended up swapping it for a different board.
Reply 7632 of 58436, by Skyscraper
Im on a roll 😀 2x Pentium Pro 512 KB for 26 Euro.
Not as cheap as the board with memory and CPUs but still.
Reply 7633 of 58436, by Blurredman
It depends, as long as the DIMM (SD-ram is a class of dimm, not simply the type in it's wholeness) is the same spec as the SIMM (Ie EDO) and at the same voltage they can sometimes work together fine. For example, I have two 16mb sticks of SIMM and one 16mb stick of DIMM (all edo) making a total of 48mb ram. The only downside is that the board stil can not exceed the normal max.
Ie 3x dimms of whatever spec (edo/sd-ram/etc) of a max of 128mb each reaches a board of that era's max of 384mb. SIMM's come in pairs however, and I gather that each simm slot takes 1x 64mb EDO. And to have one in each slot gives you a total 'bank' of 128mb. Now in order to pair it up with DIMM then bank 0 (or it could be DIMM slot 1) has to have nothing in it at all. Thus you can still max out the board's 384mb with 256mb of EDO DIMM and 128mb (2x 64mb -one bank remember) of EDO SIMM's...
But of course, it depends whether the voltage requirements are the same (otherwise you'll fry the DIMM's, they're on a lower voltage) and whether the board can physically do this. Plus EDO DIMM is quite difficult to find.
http://blurredmanswebsite.ddns.net/ 😊
Reply 7634 of 58436, by Indrid Cold
Bought this 'little' boy, this morning: ViewSonic P220f 22" CRT, for my FreeDOS & Win9x builds... boys, this is HUGE (and heavy 😜):
Reply 7635 of 58436, by Anonymous Coward
I had a similar View Sonic but it was a mere 19". I remember that thing was huge and weighed a tonne. I can only image what 22 inches feels like.
Reply 7636 of 58436, by pewpewpew
55lbs; I've got two. They remind me that whatever I think of the quality of CRT, I'm getting too old to heft the stuff. My big-screen future is inevitably panel.
Reply 7637 of 58436, by jwt27
I have two of these... 64lbs. And another one that's even heavier. Not much fun hauling these to/from the attic. 🙁
http://i.imgur.com/fpogu9Q.jpg
Reply 7638 of 58436, by kithylin
It gets a tad personal here but I won't go in to all the details. Just that I got smashed head-on by a drunk driver 9 years ago, and even though I'm only 32 now.. already my back is already permanently damaged in several spots. So no more lifting heavy things for me. I have enough difficulty hauling my towers from a couple older machines from the floor to a desk even though it's just about 6ft distance, and they're only average about 30-40 lbs. Moving a CRT around is out of the question for me. I could do it but I'd end up sore for a few days afterwards, so.. nope. All LCD's and LED panels for me now, and I have to cope with whatever issues they might bring using em on old computers, no choice.
Reply 7639 of 58436, by devius
I used to have a Eizo 21". Awesome picture quality, terrible form factor and weight. When I replaced it with a 22" LCD I never looked back... until I found out that LCDs don't support resolutions lower than 640x480 😠
