First post, by ibm5155
Well, many of you guys may know me about the problematic system that I got 🤣 so I decided to move ahead and try another mb (well a mb + cpu + ram kit), and I was kinda sad since I only could find only the bad SIS 530 mbs (without agp slot, and not many pci slots, plus weak onboard gpu)...
At my Research I found this guy, and ASIS P5A-B V1.04
Here's some pictures from the seller, so, does it looks fine? (it comes with a K6-II 533MHz [I think it's Over clocked] and 256mb sdram)
Also with that I could replace the ram and the cpu from the other mb that I have to test if the ram or the processors were bad, or, the motherboard itself.
I head this guy has 512kb l2 cache that could handle 256mb ram fine, also, a bios that can be upgraded from the mother board \o/...
So, should I check anything before I get this thing? (I already have an almost full lenght isa sound card and this mb at leasy support it, an pci ethernet, pci usb 2.0 and an voodoo 3 3000 agp.
I'm actually more worried about the sound card, because I think I'll not have enough free pci slots (the full isa slot is shared with the pci, damn u engineers), and then I would need to not use one pci slot or, try to twist a bit the jumpes to fit the isa sound card on the latest slot (and that's what I did on the other mb, almost all jumpes wasnt twisted just the power led that wasn't on the best position 🙁
