First post, by auron
hi, i hope somebody can help me with this. i have been attempting to recap my mt-32 (old) since there was some flickering on the lcd and i thought this is probably due to dried caps. unfortunately i'm a total noob at soldering and so i wound up breaking two vias by ripping off the barrels. they came right off when pulling out the cap. this happened on c32 and c70, positive side on both.
i'm hoping to be able to fix this mess by jumping some wires. from what i can tell there are only traces at the bottom going from those two vias. c70 seems pretty straightforward with the trace going straight to to the cpu, so i'm assuming i can just follow that: http://i.imgur.com/pEOlGjM.jpg
but c32 seems more complicated since the signal path is branching off here. http://i.imgur.com/rsLvXaT.jpg (the empty via is the broken one) what am i supposed to solder here in order to fix this?
here is a full mainboard pic for reference: https://upload.wikimedia.org/wikipedia/common … _1_PCB_View.jpg
also can somebody share a good trick to clear a via from solder in general? am i supposed to use desoldering wick? im using a solder sucker but it doesnt work all that great.
