First post, by Niezgodka
Hi. I try to install drivers for ESS1978. Would you post your autoexec and config sys settings?
I have no option of installing Windows 98 (no cd-rom) so it is very important for me.
Regards.
Reply 1 of 7, by traxxion
To be honest, I am not having much success getting the Maestro 2E in my Compaq M300 working consistently, so I'm just about ready to give up on it in DOS, but I think as far as the config/autoexec go it is just:
config.sys
device=c:\aecu.sys
autoexec.bat
c:\MAESTRO.COM
However, the DOS sound will not work without a functioning Windows 98 install, because it uses the resource settings specified in Windows, so this may not help you
Reply 2 of 7, by Niezgodka
I have a problems with installation of Windows 98. I have PCMCIA DVDROM. I have a boot disk for it. However in the middle of instalation it asks me if I'm installing from PC card. Then, no matter what I do I have multiple drivers problems, including no sound.
Reply 5 of 7, by PhilsComputerLab
Niezgodka wrote:
You mean to copy installation cdrom on hdd and run it from there? I never tried it.
Yup, that works very well 😀
I copy it into C:\W98 and run it from there. Also makes installing drivers easier when it needs to ask for the Windows 98 CD.
YouTube, Facebook, Website
Reply 6 of 7, by lolo799
Should I install Dos first or after Win98?
Just use your boot disk for the pcmcia dvd-rom and copy the win98 directory to your hdd, no need for the entire cdrom.
Reply 7 of 7, by Niezgodka
Ok. I have Windows 98 on Drive C. Sound works on it. Now I installed DOS 7.10 over Windows. I use dos settings for a card (autoexec and config). Some programs recognize SBPro, its DMA and IRQ but no still sound.
Maestro during booting recognizes card as well.
Should I install DOS on another partition? Install it first before windows?
