First post, by Dreamer_of_the_past
Have any of you actually personally tested performance of Katmai vs Coppermine? Especially in games. I heard some rumors that Katmai with its slower, but bigger 512KB cache is actually faster than Coppermine with its faster, but smaller 256KB cache. Yes, I am aware that majority of hardware sites if not all say otherwise which is why I would like to see some personal benchmarks to be sure.
Reply 1 of 11, by Tetrium
Try here? The Ultimate 686 Benchmark Comparison
It's very extensive and both Coppermine and Katmai were used.
My retro rigs (old topic)
Report spammers here!
Reply 2 of 11, by Dreamer_of_the_past
Unfortunately it probably won't help, since the only way to find out which one is better is to do a fair test between the two cores. Means, both CPUs have to be of the same frequency and have the same FSB, but I guess nobody has done anything like that and people just refer to hardware sites.
Reply 3 of 11, by HighTreason
If it's any help, the Mendocino Celeron 300 (Celeron 300A) was regarded by some as being equal to or faster than a Pentium II 450MHz (Deschutes) in some applications, possibly due to its on-die full speed cache. Of course, this meant running the CPU out of spec - 100MHz instead of the rated 66MHz FSB. This was, in fact, fairly common practice for a time due to the high price of the Pentium cartridges.
Though indeed, you will only find out by testing unless I get around to it first - which is not likely - let us know if you do though, because I have always wanted to run this test myself and have never found time or a good enough excuse to spend the money.
Reply 4 of 11, by PhilsComputerLab
I wanted to know this when I did my V2 CPU scaling project.
It's a 65 pages document with 875 benchmark results and on page 33 you can find information about Katmai vs. Coppermine 😀
http://www.philscomputerlab.com/uploads/3/7/2 … ing_project.pdf
Keep in mind these are V2 benchmarks only.
YouTube, Facebook, Website
Reply 5 of 11, by Dreamer_of_the_past
My experience was different back in those days. Celeron was like a turtle compare to Pentium II. I see, well cost is no longer a problem.
Yeah, unfortunately time is also a big factor here and I just don't have equal CPUs based on both cores. In addition to it, I want to build a system on i820 first, because I have this strange feeling that i820 is highly underestimated over i815.
PhilsComputerLab wrote:
I wanted to know this when I did my V2 CPU scaling project. […]
Thanks Phil, I'll take a look at it right now. Great job, it seems that the only major advantage of getting Coppermine over Katmai is lower electricity consumption.
Reply 7 of 11, by Dreamer_of_the_past
alexanrs wrote:
/\ Did you happen to have one of those dreadful cacheless Celerons? Those are supposed to be worse than Pentium MMXs they were supposed to replace.
Well, it was a long time ago, so I don't even remember, but probably so. Since then I stay away from Celerons.
Reply 8 of 11, by Tetrium
The Mendocino ones are actually quite nice. About as fast (or almost as fast) as a similarly clocked Pentium II while running at a lower FSB. These chips are often the only ones that will work on s370 LX boards.
The 800MHz+ ones are also not that bad, but not as good compared to similarly clocked Coppermines as the Mendocinos were compared to the Pentium IIs. Just stay away from the 66MHz FSB Coppermine ones as those run at a by then very low 66MHz FSB and as there are simply much better chips available for the boards those Celerons are compatible with.
I don't know about later Celerons, but I suppose the ones past Netburst might've been alright?
Reply 9 of 11, by gdjacobs
Considering the fact that a big chunk of the 300A supply were installed and run 450 mhz without even trying hard, it's no surprise it was the way to go back then.
Reply 10 of 11, by sgt76
That and the fact that Katmai doesn't scale much over 600mhz, whereas Coppermine does about 1ghz.
