First post, by schadenfreude1
- Newbie
Yo soon-to-be-friends! As the subject states, I'm trying to install a CT4520 AWE64 Value ISA sound card into my Pentium 1 MMX machine (200MHz, 64MB RAM) and am running into a problem. I've never set up a "plug and play" sound card before in DOS, so I followed Phil's YouTube guide here: https://www.youtube.com/watch?v=xaf4lWI2TEk
Following his guide, I went to the Creative site, downloaded ctcmbbs.exe and sbbasic.exe, extracted them both, then ran through the installation, basically selecting defaults for everything. The one thing I noticed that seemed off was that the installation didn't install AWEUTIL nor did the BLASTER environment variable contain an Emu8000 port.
When I run CTCM, here's what it outputs:
wrote:Found Creative Plug and Play card: Creative SB16 PnP
Successfully configured 3 of 3 Creative Plug and Play devices.
BLASTER environment is set at: A240 I10 D3 H7 P300 T6
I've also tried installing from the AWE64 CD found on vogonsdrivers.com, but it leads to the same result. I even updated the firmware of the card as mentioned here, but the end result is the same.
At this point, I assume either 1) The sound card is faulty; or 2) The software is failing to detect that the card is AWE-compliant and more than just a Sound Blaster 16.
Here are the contents of AUTOEXEC.BAT and CONFIG.SYS:
wrote:SET SOUND=C:\SB16 SET BLASTER=A240 I10 D3 H7 P300 T6 SET MIDI=SYNTH:1 MAP:E SET CTCM=C:\CTCM C:\SB16\DIAGNOSE /S /W=C:\WINDOWS C […]
SET SOUND=C:\SB16
SET CTCM=C:\CTCM
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S /W=C:\WINDOWS
@ECHO OFF
PROMPT $p$g
LH /L:2,28288 C:\WINDOWS\MSCDEX.EXE /S /D:IDECD000
LH /L:0;2,3328 /S C:\CTMOUSE\CTMOUSE.EXE
:C:\BLASTER\SBP-SET /M:15 /VOC:15 /CD:15 /FM:15
:C:\JOYKEYS\JOYKEYS /K /ALeft=GLeft /ARight=GRight /AUp=GUp /ADown=GDown /A1=RAlt /A2=" " /B1=RCtlGOTO %CONFIG%
:BASE_CONFIG
PATH C:\DOS;C:\;C:\WINDOWS;C:\UTILS;C:\TC\BIN
GOTO END:FULL_CONFIG
C:\WINDOWS\net start
C:\DOS\SMARTDRV.EXE /X
PATH C:\WINDOWS;C:\DOS;C:\;C:\UTILS;C:\ACRODOS
SET TEMP=C:\DOS
GOTO END:END
wrote:DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF DEVICE=C:\DOS\EMM386.EXE NOEMS BUFFERS=15,0 REM ** FILES=30 DOS=UMB LASTDRIVE=D FCBS=4,0 re […]
BUFFERS=15,0
REM ** FILES=30
DOS=UMB
LASTDRIVE=D
FCBS=4,0
rem DEVICE=C:\DOS\EMM386.EXE noems[COMMON]
DEVICE=C:\CTCM\CTCM.EXE[menu]
MENUITEM=base_config,Base Configuration Only
MENUITEM=full_config,Normal Configuration
MENUDEFAULT=base_config,5
MENUCOLOR=14,1[common]
DEVICEHIGH /L:1,33760 =C:\CDROM\AOATAPI.SYS /D:IDECD000
DOS=HIGH
STACKS=9,256
SWITCHES=/F[base_config]
[full_config]
DEVICE=C:\WINDOWS\IFSHLP.SYS
DEVICE=C:\DOS\SETVER.EXE
[COMMON]
FILES=40
Thanks!
