Reply 10161 of 58450, by kanecvr
- Oldbie
wrote:
I have that exact motherboard myself. Really nice for a compact retro rig. I put mine in one of these http://images10.okr.ro/auctions.v3/700_700/20 … 249-700_700.jpg - Delux M198 SFX Micro ATX chassis.
Reply 10162 of 58450, by rein_ein
- Member
wrote:wrote:I have that exact motherboard myself. Really nice for a compact retro rig. I put mine in one of these http://images10.okr.ro/auctions.v3/700_700/20 … 249-700_700.jpg - Delux M198 SFX Micro ATX chassis.
Nice case,first of all i'm planning to find 1ghz Coppermine,alrady have mini-tower no-name case for that 😀
Reply 10163 of 58450, by Tetrium
- l33t++
wrote:
That board looks really cute!
Only grip I can see is the position of the PS connector above the CPU socket which looks like it will be between the CPU socket and the PSU once mounted inside a case.
And the stock Intel HSF is well suited for Super 7 which have motherboard components preventing installation of a larger HSF (perhaps replace the fan though as some of those Intel ones weren't exactly a pleasure to be hearing all the time).
Reply 10164 of 58450, by kanecvr
- Oldbie
wrote:That board looks really cute!
Yeah that's really annoying. It won't let you use a big quiet socket a cooler. Even if you use a small noisy cooler the ATX connector touches it and is a pain in the ass to remove w/o removing the cooler first.
Reply 10165 of 58450, by carlostex
- l33t
Got these today:
Reply 10166 of 58450, by keropi
- l33t++
that WDC vga is a fast one , nice catch!
It has some interesting utils that let you chose mda/cga/ega modes , it reboots your pc and the card acts according to your choice.
Reply 10167 of 58450, by carlostex
- l33t
wrote:that WDC vga is a fast one , nice catch!
Thanks Leo!
I'm aware of the paradise card utilities i've been experimenting all kinds of vga cards for an XT.
Reply 10168 of 58450, by havli
- Oldbie
P4 1.8A (Northwood core). Sorry for the lower photo quality, these things are not very camera-friendly 🤣
Reply 10169 of 58450, by Skyscraper
I bought some new memory in December but I diddnt open the package until now. 😀
I have also bought alot of Socket-3 and Socket-7 CPUs with bent pins over the last year but diddnt bother to fix them all until now.
The new memory.
The "new" Socket-7 CPUs. (80% is from the last year, besides these I have perhaps 10 more Socket-7 CPUs).
The "new" Socket-3 CPUs. (All except one are from the last year, besides these I have perhaps 10 more Socket-3 CPUs).
Reply 10170 of 58450, by PhilsComputerLab
Reply 10171 of 58450, by kixs
- l33t
wrote:wrote:Got these today:
Very nice that Speedstar 24X. I have one too, it's my fastest ISA card, tied with my ET4000 😀
Bought one in the beginning of December and still haven't received it 😢
I hope it arrived today as I got a message from the Post that a few packages are waiting for me 😁
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 10172 of 58450, by Tetrium
- l33t++
wrote:I bought some new memory in December but I diddnt open the package until now. :) […]
The new memory.
That's an awesome haul, cheers! 😁
I couldn't spot any 16MB 30p SIMMs though, but you do seem to have at least 3 72p SIMMs with at least 16MB RAM (32 of the other side is populated also).
The fastest way to distinguish the 4MB (8MB if double sided) and 16MB (32MB if double sided) is by counting one row of legs on one of the chips (this trick works for the SIMMs which have 8 chips all of the same size and were very common back in the day), if a SIMM has 2x5 legs, 8 chips make 4MB and if the same SIMM has 2x6 legs, 8 chips give you 16MB.
I didn't spot any particularly rare CPU though (mind you, I'm not an expert here 😜) but the It's ST DX4-100 is nice to have.
3 K6-III+'s along with a bunch of K6-2's.
You should check your Pentiums to see which ones have the imfamous FDIV bug 😜 (theres a list of all Intel part numbers which have this bug. Alas, none of my Socket 5 Pentiums seemed to be affected, but one of my Socket 4 chips is 😁)
Is your chip with "i50" engraved on the bottom (the right most chip with heatsink attached on your Socket 3 CPU pic) a DX or a DX2? I kinda forgot how these were exactly marked.
Reply 10173 of 58450, by Skyscraper
wrote:That's an awesome haul, cheers! :D […]
The new memory.
The fastest way to distinguish the 4MB (8MB if double sided) and 16MB (32MB if double sided) is by counting one row of legs on one of the chips (this trick works for the SIMMs which have 8 chips all of the same size and were very common back in the day), if a SIMM has 2x5 legs, 8 chips make 4MB and if the same SIMM has 2x6 legs, 8 chips give you 16MB.I didn't spot any particularly rare CPU though (mind you, I'm not an expert here 😜) but the It's ST DX4-100 is nice to have.
3 K6-III+'s along with a bunch of K6-2's.You should check your Pentiums to see which ones have the imfamous FDIV bug 😜 (theres a list of all Intel part numbers which have this bug. Alas, none of my Socket 5 Pentiums seemed to be affected, but one of my Socket 4 chips is 😁)
Thanks, fixing the pins sucked though.
The lion's share of the memory are small FPM modules with or without parity but there are some larger EDO modules aswell.
There are exactly 0 rare CPUs pictured because I do not own any rare Socket-7 or Socket-3 ones. 😁
The CPUs with i50 engraved are DX2-50 CPUs and the ones with i66 engraved are dx2-66 ones. The marking was made to detect fakes.
Reply 10174 of 58450, by Tetrium
- l33t++
wrote:Thanks, fixing the pins sucked though. […]
About the straightening out of CPU pins, theres always the universal pin corrector method 😁
When using the UPC, be careful not to put too much force on the part of the pin that's very close to the CPU or you increase the risk that it will break (hard to explain), but this method sure beats using fingernails 😜
This method is less effective though for pins on CPUs like s370 Coppermines and beyond (Pentium MMX and the black s370 Celeron should be fine though), I found those pins to be very brittle compared to the ones used on ceramic CPUs like the original Pentium.
Reply 10175 of 58450, by sirlemonhead
- Member
Yeah a mechanical pencil is great for fixing bent Pentium pins! 😁
Reply 10176 of 58450, by mmx_91
- Member
I used to use a credit card to align back the pines of CPUs from classic Pentiums to AM2 Athlons, by inserting it through the rows of pines till it reaches the other side (it means, no more bent pines there!). The ones that are seriously bent, I push them back into position by using the same card or the well-known mechanical pencil method 🤣.
EDIT: http://pad3.whstatic.com/images/thumb/e/e5/Fi … -CPU-Step-4.jpg 🤣
Reply 10177 of 58450, by PhilsComputerLab
- l33t++
Got this off eBay last year and it arrived today 😀
This is fairly new gear, but I have nothing that is SLI compatible. My only SLI experience is with 3dfx Voodoo 2 cards.
Let me tell you, I never had such a high end board. I always go for very basic and cheap uATX boards, so this was really treating myself 😀
This board is fully XP compatible and supports SLI as well as CrossFire. FX8350 CPU, but I can use my other AM3+ processor as well. And four 4 GB sticks of RAM.
I plan on playing around with SLI, always makes for a good video. Like 7900 GTX SLI for Splinter Cell Pandora Tomorrow?
Reply 10178 of 58450, by havli
- Oldbie
wrote:7900 GTX SLI
Microstuttering generator. 😈
Reply 10179 of 58450, by PeterLI
Picked up a Compaq Armada 1700 at a thrift store today. Hope to use it for RA2 this Saturday.
