Callahan wrote:Where did You saw that it's not a 168 pin module???
My mommy and daddy taught me how to read and count around 50 years ago.
I would give you a referal but they aren't taking new clients.
It's completely beyond me why in a thread about wierd RAM you would go out of your way to make a really cool weird non-PC proprietary module look like normal PC RAM, but that appears to be what you are doing.
Image 1 - Your first photo reduced to a forum-reasonable size.
Discussion below it.
The one on the right is this so-called universal voltage module that you claim works in both 3.3v only and 5v only systems.
As will be shown it is not universal voltage. - And those systems are both 3.3v.
From left to right
Standard 168p 3.3v PC100 SDRAM Unbuffered no-ECC
Samsung KM44S4020CT-G10 chips [7ns] http://www.datasheets360.com/part/detail/km44 … 32912055409819/
Standard 168p 3.3v EDO Registered ECC
Samsung KM44V4004BK-6 [60ns] http://www.datasheets360.com/part/detail/km44 … 18457082961697/
Standard 168p 3.3v EDO Unbuffered ECC
Elpida 5165805FTT-5 [50ns] http://www.datasheets360.com/part/detail/hm51 … 66504921927109/
Toshiba TC5165805AFT chips [50ns] http://www.datasheets360.com/part/detail/tc51 … 51561956241239/
Next the one on the extreme right. - The supposed "universal voltage" unusual module.
Stanadrd 168p 3.3v EDO Unbuffered ECC - with non-JEDEC compliant keying
Micron MT4LC4M4E8DJ-6 chips [60ns] http://www.datasheets360.com/part/detail/mt4l … 92275925446271/
(The datasheet you referenced does not say they do both voltages. It says they can do either voltage. Read the whole thing.)
- The "LC" voltage code MT4LC4M4E8DJ = 3.3v - This is what is on the module.
- The 5v part is voltage code "L" MT4L4M4E8DJ - Not what is on the module.
My speculation is it was manufactured by a really cheap-ass company that didn't want to fork out the cash to have both 5v and a 3.3v PCBs made for their modules.
You claimed this 'universal voltage module' works in two systems that use different voltage RAM.
The thing is those two systems do not use different voltage RAM.
Callahan wrote:
3,3V modules works with compaq proffesional workstation 5000 (dual ppro) - Yes
5V modules works with compaq proffesional workstation 5100 (dual pII) - No
The Compaq Professional Workstation 5100 also uses 3.3v 168p RAM - see pic.
Image: RAM ads for Compaq Professional Workstation 5100
