ramiro77 wrote:Nothing helped. I tried clearing CMOS taking the battery off, I tried every bios setting, I tried changing the psu to see if tha […]
Nothing helped. I tried clearing CMOS taking the battery off, I tried every bios setting, I tried changing the psu to see if that helps and nothing. I tried it in the three PCI slots too. It does work ok with my Trident 9680, but if I put the TNT2 and the Trident at the same time with the CRT connected to the Trident, the system wont display anything too. It boots, I hear the hdd loading windows but no display. I also found that the power_good signal cable from my original AT psu was burning. I tried again with the other AT psu that I have for spare and everything is fine. It seems that this system is starting to show aging issues. But every stress test I ran were ok. So I don't know why the hell this isn't working. The TNT2 is working like a charm in my Deskpro EN as I said.
Regarding the Voodoo 2:
I can put those pins in place. But there is a missing pin and I have no room in the chip to place a wire. One solution could be drilling something like 0.5 - 1 milimeter the chip to make place and insert a thin pin and join it with what remains of the original pin. Another solution could be replacing the entire chip, but It's 99.99% unlikely finding a spare chip or another blown card at decent price in here.
And the Voodoo 1 still needs replacing some caps. I'm not possitive at all, but besides the issues with the TNT2 and my retro rig, I bought a bunch of working stuff at really low price. Sure, It will be a pity if I can't fix them. But they were something like a gift so I can't complaing too much about it.
Are you absolutely sure a pin is gone? Doesn't look like it on the photo. [Edit: forget that, on a closer look, it does indeed] Also, the pins are broken close to the PCB, so I'm positive that be fixed pretty easily by someone with some soldering experience. Straighten and position the pins as close to how they used to be as you can manage, it's important that the broken ends are as close to each other as absolutely possible. Apply liquid flux generously, and drag solder it using a thin hollow bevel tip. If you manage to bridge some pins, just apply more flux and redo the soldering with less solder on the tip. Be careful to not bend the pins again when soldering, be as light handed as only possible.
If a pin really is gone, some pin breaks while straightening them out, or you just can't get some of them close enough to their corresponding broken ends for the surface tension to do its work while soldering, you can use a thin cable strand as a sort of a wick. Make it a few centimeters long, tape one of its ends to the PCB, position the loose end to bridge the gap between the broken pin parts, apply flux, solder, cut off the excess part of the strand.
Afterwards, be sure to wash away the flux residues carefully, even if you use no-wash flux.
Hope I made any sense, English is not my native language 😀
