First post, by Gigagator
Hi all,
I'm having a weird problem with my old CRT monitor that I use for my old 95 gaming system.
Basically, it works perfectly but then it randomly begins to flicker with large horizontal bars moving up/down the screen.
It looks similar to a TV with bad vertical hold settings and it becomes almost impossible to use the PC as I can't make anything out.
The strange thing I find is that to fix this problem, I have to just twiddle the power cable going into the back of the monitor and it goes back to normal.
I've opened up the monitor casing and the power supply jack isn't look on the PCB so I don't think it's that.
Can anybody suggest what the problem could be and if there's anything I can do to fix it?
This is quite an old monitor, the original that has been in my family since 1996 or something and I really don't want to have to throw it out.
Thanks.
