Reply 10660 of 58436, by gdjacobs
S754 offered excellent value in it's time, but S939 will tear it apart in terms of memory bandwidth. K8 hit internal bandwidth limits with AM2 and DDR2.
I don't know what availability is like, though. My suspicion is that will be the dominant consideration when choosing between S939 and S754.
Reply 10661 of 58436, by havli
PhilsComputerLab wrote:
I think I have that same 754 processor, it makes for a very decent Windows XP gaming machine. Socket 939 really isn't that faster I found, but I haven't checked out any dual core CPUs yet.
Well, for me K8 is not fast enough for XP gaming rig (no AMD CPU is good enough for that actually). But this A64 is nice CPU for my collection and maybe it will take part in rather extensive tests.
Reply 10662 of 58436, by Lukeno94
Why would you need anything more than an A64 for an XP rig? Any game that is more demanding should surely run better on Windows Vista/7/8/10 anyway, particularly with those OSes supporting newer DirectXs and such.
Reply 10663 of 58436, by havli
Because I want games to be perfectly smooth (100+ fps) and A64 is way too slow for that. Also plenty of games dont run on win10 very well... but still need lot of performance. For example NFS U2, NFS MW, Bioshock, etc.
Reply 10664 of 58436, by PhilsComputerLab
I understand that 😀
YouTube, Facebook, Website
Reply 10665 of 58436, by kithylin
All of those games you listed would get better performance from Vista or Win7, and usually run slower in XP in comparison. And not really "XP Gaming" games anyway.
By the way, a K8 dual core @ 2.6 ghz is just as fast as most of the earlier revision, mid-range core2duo chips, a lot of K8 platforms support 8GB and 16GB ram and can run Win7/Vista.
Reply 10666 of 58436, by Cyrix200+
Did not buy anything for a while, but saw these for just a few bucks so could not let them sit there:
ZXAiYVPl.jpg?1
1982 to 2001
Reply 10667 of 58436, by havli
I don't run any Vista/7 gaming PC at the moment ... and these games most definitely works better on XP than win 10. Also A64 X2 5000+ is much slower than C2D. For example NFS U2 avg fps -> X2 5000+ = 75 fps (22 min), C2D E6600 = 99 fps (58 min). Since I want stable 120 fps (built-in frame limiter), K8 is out of the question and Core 2 as well.. except maybe E8400 @ 4 GHz or something like that.
Reply 10668 of 58436, by brostenen
Cyrix200+ wrote:
Did not buy anything for a while, but saw these for just a few bucks so could not let them sit there: […]
ZXAiYVPl.jpg?1
That DEC cpu.... Is that gold, wich the nuts are screwed on to? Never seen that before. Looks cool. 😜
Reply 10669 of 58436, by Lukeno94
What resolution are you even running these at? NFS U2 is from 2004 and is a fairly well optimised game, it shouldn't need anything like that kind of horsepower. I don't remember ever having framerate issues on an Athlon XP 2200+ and GeForce FX something at 1024x768 or 1152x864 back in the day!
Reply 10670 of 58436, by havli
1280x1024, noAA, maximum details (including the advanced settings). Using GeForce GTX 285, so this is clearly a CPU test. And btw - this benchmark was performed on windows 7.
I can post fps of other CPUs, but I'll rather create separate thread for that. It is OT here. 😊
Reply 10671 of 58436, by nforce4max
ZXAiYVPl.jpg?1
Gold electroplate, they made real quality back then.
Reply 10672 of 58436, by RacoonRider
Last time I played it, it was on AXP 3200+/9800Pro. 1280x1024, maximum settings, don't remember if I used any AA though. Seemed to run pretty smoothly, I didn't care to measure FPS though.
Reply 10673 of 58436, by gdjacobs
ZXAiYVPl.jpg?1
Even the cheap Alpha chips were sexy beasts and pretty monstrous on performance as well. HP should have never dropped it for Itanium.
Reply 10674 of 58436, by Cyrix200+
brostenen wrote:
<snip>
Yes, I had never seen one, just pictures before... I have no use for it unfortunately and I have no idea if it is in working condition...
1982 to 2001
Reply 10675 of 58436, by Indrid Cold
Today a friend of mine has made me a surprise, bringing me as gift a box of cables, drives, one case, etc - the thing I like more is this motherboard:
I would like to make a retro-build with an architecture like this one, but I don't know if that motherboard is better than this one I've found time ago (maybe this is more confortable for the AT/ATX power connector):
I also got this video card I can't recognize, but It seems almost equal to another one I've already own:
And this little C2D E2160:
Reply 10676 of 58436, by gdjacobs
I don't know Lucky Star, but I can tell you the TX97 series is pretty solid. My TX97 was used when I got it 15 years ago and still going strong.
As they're TX based, both don't cache beyond 64MB, but that should be fine for DOS and perhaps early Windows 98 gaming.
Reply 10677 of 58436, by Indrid Cold
Thanks, I'm going to use this one then - no problem for the memory caching limit, I'll use the build ONLY as pure MS-DOS/FreeDOS system.
Reply 10678 of 58436, by rein_ein
Nice haul,specialty ss7 board.
Looks like Radeon X1050 or something like that.
Reply 10679 of 58436, by gdjacobs
They're both Socket 7, not super.
