First post, by clueless1
I wanted to see how these CPUs compare in DOS, so I benched them against each other. Sadly, the K6-2 system has only onboard AGP, no slot, so I had to use the Voodoo3 2000 PCI in both systems to keep things even. Here is some info on the K6-2 platform:
motherboard: P5S-VM rev 2.02 (out of an HP Pavilion 6648c)
Socket 7, SiS530 chipset, 3xPCI, 1xISA, onboard SiS AGP graphics
active graphics: Voodoo3 2000 PCI
and the Celeron platform:
motherboard: P2L98-XV rev 1.02 (out of an HP Pavilion 6355)
Slot 1, i440LX chipset, 1xAGP, 2xPCI, 2xISA, onboard ATI Mach64 AGP graphics
First up: 3dbench.
K6-2 550: 242.1 fps
Celeron : 216.4 fps
Celeron w/Fastvid: 492.3 fps
PCPbench:
K6-2 550: 108.1 fps
Celeron: 87.6 fps
Celeron w/Fastvid: 101.5 fps
Doom:
K6-2 550: 93.7 fps
Celeron: 81.2 fps
Celeron w/Fastvid: 89.6 fps
Quake:
K6-2 550: 68.2 fps
Celeron: 71.5 fps
Celeron w/Fastvid: 79.9 fps
Both are very fast, but it looks like the Celeron is better at floating point (Quake) and once Fastvid is used, they perform very similarly.
Cheers!
Reply 2 of 18, by clueless1
elianda wrote:
Did you enable Write Combining on the K6-2 as well?
I'm pretty sure there is no toggle for that in the HP-branded BIOS, but I have to check. Unfortunately, I don't have the system set up at the moment so I can't check quickly. But I will in the next day or two.
Reply 3 of 18, by elianda
I mean you used FASTVID to set the MTRRs of the Celeron. SETK6D is the tool that does the same for the K6-2. It can be run from the command line just like FASTVID.
If you compare the CPUs make sure you have an equivalent configuration.
Youtube Channel
Reply 4 of 18, by clueless1
Good to know, thanks. I will have to investigate SETK6D. I had never heard of it until now!
At least the comparison without FASTVID does provide equivalency.
Reply 5 of 18, by noshutdown
i pitted k6-3+550 against celeron300a oc 450 in 3 benchmarks: superpi, 3dmark01 and quake3.
the celeron won all 3 tests. in quake3 its around 50% faster, the other two tests just saw ~5% difference but remember that the celeron has 100mhz lower clock.
Reply 6 of 18, by Stermy57
I have some questions about your benchmarks because:
It's important to know what kind of chipset was used ( even onboard cache if 512kb-1mb etc)
Gpu model and driver version
Celeron 300a slot@450mhz does mean that you push it at 100*4,5 and i think that with these settings you can't compare an amd k6-3+. They work in different way.
If i were you, i would use a pentium II 450 100*4,5 instead.
Reply 7 of 18, by Tertz
Doom:
K6-2 550: 93.7 fps
Celeron: 81.2 fps
Celeron at 333? then it's ,lol
In tests package there is mtrrlfbe, wich probably works on K6 too.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 8 of 18, by clueless1
The Celeron 300 was a famous overclocker. It defaulted to 66Mhz FSB and 4.5 multiplier. Simply by setting the FSB 100 it "became" a Pentium II 450. In fact, many review sites at the time compared it to the Pentium II 450 and found it to perform identically. Example: http://www.anandtech.com/show/174/4
Reply 9 of 18, by clueless1
Tertz wrote:
Doom: K6-2 550: 93.7 fps Celeron: 81.2 fps […]
Doom:
K6-2 550: 93.7 fps
Celeron: 81.2 fps
Celeron at 333? then it's 🤣
It seems the K6-2 is faster in situations where there is already more than enough performance, whereas the Celeron is faster in situations where it would actually make a difference in playability.
Reply 10 of 18, by Tertz
Not all of them could be overclocked, but some 300a worked even at 495 MHz 😀
If you want more testing, welcome to benchmark in my signature. 1st half of its tests. There is no data about K6.
Yamaha YMF7x4 Guide
Reply 11 of 18, by Stermy57
I know that the Celeron 300a was famous for his overclocking's skills but if you push it from 66mhz to 100mhz you will not only increase cpu frequency but even agp and pci frequency.
From 66 to 100 agp and pci frequency will work at 100mhz and 50mhz instead of 66 and 33.
Edit: Not all slot1 mainboard have fix
Reply 12 of 18, by havli
Most chipsets support AGP divider 2/3 and PCI divider 1/3, so no problem running FSB 100.
Reply 13 of 18, by gdjacobs
Many (most?) boards were equipped with the proper dividers for 100mhz FSB operation as that was supported by several PII CPUs. So, unless the motherboard is very bad, the secondary buses will run at stock clocks.
Reply 14 of 18, by alexanrs
Only if the motherboard does not support the correct dividers, which it should if it also supports the 450MHz Deschutes Pentium II.
Reply 15 of 18, by happycube
In this case, it's running on an OEM 440LX board, so there's little/no overclocking. But OC'd to a 90-100mhz FSB it would probably curb stomp the K6-2 at it's top OC...
Reply 16 of 18, by noshutdown
well, maybe except the boards with earliest lx chipset.
as alexanrs mentioned, such boards withonly 66fsb support could not support p2-350 or higher which were rated for 100fsb, just like the standard 66fsb socket7 boards for k6-2.
in fact, i don't think there are any viable choices of slot1 boards other than the bx, which kept on sale for 3 years.
Reply 17 of 18, by shamino
I remember when I was researching my K6-3 upgrade back then. That was right around the time the Celeron 300A was getting popular. I totally ignored Celerons because they were only 66FSB and just because they were "Celerons". I didn't know much about overclocking back then and even if I'd been more informed, I wasn't comfortable with it. I would have been scared to deviate the slightest bit from specifications.
Pentium-IIs and the required parts I'd need to go with them were too expensive.
I ended up enamored with the K6-3 so that became the focus of all my research.
I don't remember what the pricing was like anymore, but I wonder what it would have cost to go the Celeron route instead of K6. I remember one problem was that I didn't want to have to buy a new case and PSU, so I was trying to stay on AT. But I guess there were some 440BX Baby-AT boards.
It seems Intel was a bit ahead of the curve with their FPU performance, starting with classic Pentiums. It wasn't important for mainstream users until 3D games came along, and then AMD and Cyrix became glaringly deficient.
Reply 18 of 18, by clueless1
In that Anandtech review I linked, they mentioned the Celeron 300a price at $180, if that helps. I'm sure it wouldn't take much to pull the rest of the numbers if you're curious enough. 😉
