Reply 10860 of 58862, by brassicGamer
- Oldbie
wrote:One AMD K6-II 300 MHz processor. Does this mean it's a Super Socket 7 (and the K6-II won't work with a normal Socket 7)?
It will work as it is voltage- and pin- compatible, but the old board will not support the higher bus speeds required by newer CPUs so it will run at a slower speed.
wrote:And another (this time Intel 😀 ) Socket 7 board, with the same problem of not having any ports except AT keyboard. This one also doesn't have an AGP slot, so I can't use it for my DOS machine since I don't have a PCI video card 🙁. Notice the kind of dorky "Mr. BIOS" chip.
There is no such thing as an Intel socket 7 board with AGP - it's only available on boards with 440LX and newer chipsets. Of course super socket 7 boards with SIS, VIA, etc. also support AGP. So you will need a PCI card. Happy hunting!
wrote:Is the "Socket 462" backwards-compatible with Socket 7?
Nope. In-between SS7 and socket 462 you had slot A - they are completely different because AMD redesigned their FSB system.
