Reply 3080 of 30910, by kithylin
- l33t
wrote:I tried to bench a K6-2 with my FIC VA-502 board. […]
I found some German forum post with supposed jumper settings for 2.5V, the board officially only supporets 2.8-3.5V and it turned out that the 2.5V setting wasnt 2.5V but some voltage that made the CPU overheat in 20 seconds or so. Well I dont really need to know how a K6-2 would perform in the FIC VA-502 and if i really wanted to I have one of those nice socket adapters.
The next thing I did was to test a Dataexpert EXP 8551 i430FX Socket-7 board from the lot of 11 "untested" boards I bought some time ago. This motherboard looked like new but it diddnt want to post, it turned out it's one of those boards that wants memory sticks in slot1 and slot3, it came with sticks in slot1 and slot2. The board seems to work just fine but the socketed ODIN RTC has run out of juice.
Now Im going to see if I can get the not all all pristine looking PC Chips "TXpro-II" board from the same lot going.
The original FIC ftp is still active.
Manual for your motherboard here: ftp://ftp.fic.com.tw/motherboard/manual/socket7/va-502/
Latest bios's buried somewhere in here: ftp://ftp.fic.com.tw/motherboard/bios/socket7/va-502/
