Let's benchmark our systems with caches disabled
Reply 41 of 194, by BSA Starfire
Ignore the score I just added with a Pentium M, neither BIOS or Setmul will disable caches so it's irrelevant.
Sorry to waste a time.
edit: never mind entry deleted.
Reply 42 of 194, by clueless1
Added a result for my POD 200 with the setmul switch 'BPD' (branch prediction disable). This slows the cpu down another 16% in Speedsys over just disabling L1. Doom framerate drops by 12.6%.
Reply 43 of 194, by clueless1
Updated POD results with new video card--TNT2 M64 PCI replaces Voodoo3 2000 PCI. Only the results with cache enabled changed. This seems to show that when you disable cache on a CPU, the video card has much less impact on performance.
Also added results with more setmul switches--
using VPD (disable V pipeline), speeds drop from P200 to P166.
using BPD (disable branch prediction), speeds drop to P133.
using DCD (disable L1 data cache), speeds drop to 486SX-25.
using CCD (disable L1 code cache), speeds drop to 486SX-20 (theoretical, based on Doom scores).
using L1D (disable entire L1 cache), speeds drop to Am386DX-29 (theoretical, going by Doom scores).
using L1D+BPD, speeds drop to Am386DX-25 (theoretical, based on Doom scores).
These switches only work with Pentiums, and apparently not all of them. Just try to see if it works.
From setmul docs:
-Pentium P54C test register "TR12" options. Parameters: BPD - Disable Branch Prediction VPD - Disable V Pipeline L1DX - Disable […]
L1DX - Disable L1 cache exclusively
CCD - Disable L1 code cache
DCD - Disable L1 data cache
PFE - Pentium Features Enable; Resets the above TR12 options to default.
The combinations I list above are the only ones I could get to give me discrete results. Other combinations did not yield new results.
Reply 44 of 194, by BSA Starfire
Results added for a AMD Duron 650 MHz on Dfi AK74 motherboard. 512 MB RAM & Nvidia TNT 16 MB STB Velocity 4400 graphics card.
Sorry I have been a bit slow on contributions, been really busy this last 2 weeks.
Best,
Chris
Reply 45 of 194, by clueless1
BSA Starfire wrote:
Results added for a AMD Duron 650 MHz on Dfi AK74 motherboard. 512 MB RAM & Nvidia TNT 16 MB STB Velocity 4400 graphics card. […]
Best,
Chris
Thanks! No worries, Chris. I appreciate any results people submit. 😀 I'd love to see some 486 results, if anyone reading this has one they'd like to benchmark.
Cheers.
Reply 46 of 194, by MMaximus
I updated the spreadsheet with results from my 233MMX build Pentium 233MMX - SCC-1 / CT2230 / Voodoo2 rig
I benchmarked 8 different combinations of CPU speed and caches but I'm just gonna post the highest and lowest results here for simplicity:
P233MMX with L1 and L2 enabled
3Dbench: 165.1
PCPbench: 55.8
DOOM realticks 903 (82.71 fps)
Speedsys 176.23
P233MMX @ 100mhz with L1 and L2 disabled
3Dbench: 10.8
PCPbench: 2.7
DOOM realticks 17304 (4.32 fps)
Speedsys 10.45
Hard Disk Sounds
Reply 47 of 194, by clueless1
Thanks, MMaximum. I see too that tyuper is adding an Intel 486DX4-100. 😀 Very cool. Regarding your results, here's some equivalents that you are hitting:
P233MMX with L1 disabled performs like a 486DX-33
P233MMX @ 100Mhz with L1 disabled performs like a 486SX-25
P233MMX with L1+L2 disabled performs like a 386DX-33
P233MMX @ 100Mhz with L1+L2 disabled performs like a 386DX-25
Reply 48 of 194, by tyuper
Nice to hear that 😀 The lowest I could get without touching jumpers:
3DBENCH: 3.4
PCPBench: 0.4
SpeedSys: 3.5
Doom: 57998 ~ 1.28 FPS
Slower are only 286-8, that's what TOPBENCH stated 🤣
Reply 49 of 194, by clueless1
tyuper wrote:
Nice to hear that :) The lowest I could get without touching jumpers: 3DBENCH: 3.4 PCPBench: 0.4 SpeedSys: 3.5 Doom: 57998 ~ 1.2 […]
3DBENCH: 3.4
PCPBench: 0.4
SpeedSys: 3.5
How did you manage this? 😀
Reply 50 of 194, by DX7_EP
I went and added my results from the vintage laptop onto the spreadsheet. It is a bit silly how my system has a bit of gap between <i386DX-16 and ~AMDX4-100 levels of performance.
It is interesting this system does allow a user to switch CPU cache write policies between default write-back and slower write-through modes in the BIOS. As a result, I've specified which mode I was using in each result set.
CM-64, FB-01, SC-55ST, SC-8850, SD-20
Reply 51 of 194, by clueless1
Just a quick note: Now that we have a decent database of results, I picked some common/popular combinations of CPU/chipset/graphics that represent their platforms well and isolated their results on their own spreadsheet tab. Also updated the OP to reflect this. Link to spreadsheet:
https://docs.google.com/spreadsheets/d/1uKhCI … dit?usp=sharing
Reply 52 of 194, by melbar
By the way, i have replaced the GF2-MX400 with a RivaTNT2 i've bought last week. It works quite well after deinstall and reinstall the same drivers.
A first test with the clock-speed which i use mostly and with all caches:
As expected, the RivaTNT2 is as fast as a GF2-MX400 (which performs with a fast CPU, let me say 1,5-2,0Ghz, between GeForce256 and GeForce256-DDR). My CPU with 170MHz is definitely too slow and also with the max. 500MHz the RivaTNT2 should be enough...
With a RivaTNT2 i have compared to GF2-MX400:
3DBench2: -0,40%
PCPBench: -0,36%
Speedsys: -0,44%
DOOM (realticks): -0,85%
DOOM (fps): -0,88%
So, no need to update the speadsheet...
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 53 of 194, by clueless1
I found that any differences between graphic cards goes completely away when you disable caches. Even comparing onboard Cirrus Logic to TNT2, there is a huge difference at full speed, but nearly identical scores after caches are disabled.
Reply 54 of 194, by tyuper
Look for "Boot Up System Speed" option in your's mainboard BIOS setup. 😀
Reply 55 of 194, by BSA Starfire
Results added for VIA/Cyrix III 600 MHz, 3dfx Voodoo Banshee.
Reply 56 of 194, by melbar
Interesting results with your Via-Cyrix III (600Mhz). With 3Dbench & PCPbench, you'll get a 486DX25-33, and with Doom you match to a 486DLC-33.
That's quite good.
When i compare my results of PIII, i've made in the past (only 3Dbench & PCPbench, with a slow RageXL), i've got these strage results:
PIII 650: 3Dbench 353.7, PCPbench 136.1
PIII 433: 3Dbench 235.7, PCPbench 105.9
PIII 433 (L1,L2): 3Dbench 58.5, PCPbench 1.4
Reply 57 of 194, by BSA Starfire
Well the VIA/Cyrix III has no level 2 to start with, so I guess that is a seriuos limiting factor. You can find my scores with a Celly Mendocino and same board on the spreadsheet too.
EDIT, I just realised those were with a a Chromatic Mpact2, so not really comparable, sorry.
Reply 58 of 194, by j^aws
Added VIA Cyrix III: Ezra-T @ 1000MHz, 1200MHz and 200MHz, using onboard VGA (C&T F69000), and on a 440BX board.
