First post, by arteq
Hello
Could you please help me with this:
I need values of the resistors and capacitor for may MB ATC - 1415, could you please send me a good quality picture or values ?
I would be thankful 😀
Best regards
    476.82 KiB
Some items for sale 😀
https://docs.google.com/spreadsheets/d/1YNG8R … dit?usp=sharing
Reply 1 of 16, by kixs
Here you go.
My board seems to have a problem with voltage regulator. It doesn't work when set to 3.3/3.45V. With 5V CPUs all is fine.
    291.72 KiB
Reply 2 of 16, by arteq
you have saved my day 😀
but one more request , my mobo also miss this transistor , could you please take a photo of it ? 😀
thx
    23.21 KiB
Reply 3 of 16, by kixs
Another one:
    139.82 KiB
Reply 6 of 16, by arteq
sure I will
but one more request , also this diode and capacitor is missing , do you mind to take a photo ?? 😀
ps
what bios version do you have ? maybe problem with 3.45v is connect with bios problem ?
    45.21 KiB
Reply 8 of 16, by kixs
arteq wrote:
sure I will […]
sure I will
ps
Diode looks the same as D5. I can't get a clear photo - lightning/focus problem.
Capacitor is the same as pictured before (CT23) - 22uF 25v.
Not sure what is the problem with voltage regulator. If I set jumpers to anything but 5V the board won't post. It works fine on 5V.
EDIT:
Adding photos...
    312.77 KiB
Reply 9 of 16, by noshutdown
i have a 486 board with similar problem, and i guess its in the voltage regulator aswell, but i am not good at repairing. 😠
Reply 12 of 16, by tereg
Hello guyz, I have same problem. It seems my MB missed capacitor.
It is CT-20 and lay left from processor (bigger than all another).
Can you help me with it? I need parameters or photo of this.
