Reply 12900 of 60083, by Ozzuneoj
- l33t
wrote:There really isn't that much difference between Vista and 7 on a decent system. A small improvement in performance, but most of what people saw was due to them upgrading to much stronger hardware than had been around at Vista's launch - and, crucially, going past 512MB/1GB of RAM. Vista got a lot of undeserved flak that actually should've been aimed at the lazy and dodgy OEMs who couldn't be bothered to stock things with proper hardware and/or drivers for said hardware - it was no more of a leap forward than XP was over 98 (which, if you think about it, was a slightly smaller time gap) in terms of system demands.
I'm glad more people are aware of this. Vista has some shortcomings, but the performance problems vs 7 tended to be hardware related. We're basically talking about a time of transition from main stream Single to Dual core CPUs, from DDR1 to DDR2, from 512MB-1GB being "all you need" to 2GB-4GB, and not to mention, the early days of the netbook era which was a huge step toward making PCs as cheap as possible... always at the cost of performance.
I remember seeing a system at Walmart back in 2007 that had... and remember this is 2007... a 17" non-flat CRT, a mini tower with a Via C7 1.5Ghz, 512MB of RAM, an 80GB hard drive and... Vista.
HOLY COW... after I typed that I wanted to search for it to see what brand it was, and actually found mention of it from 2007. And I was actually correct with the specs! 😀
https://answers.yahoo.com/question/index?qid= … 29083308AA43hU1
It was an Everex.
