This system will as far as I know be a typical gaming rig. So I could for instance use a small partition < 8GB for the OS and use one or two large partitions for installing mostly games. I guess it depends on how those games will utilize the filesystem, which may differ from game to game. For partitions larger than 32GB each folder and all files smaller than 4K would take up 8 times the space of same files in an 8GB partition. I was curious if this typically would make any practical difference, so that I would regret using the large partitions after a while seeing storage eaten away at a noticeably quicker pace. One could also as a middle way use the 16GB or 32GB limits to somewhat keep down the number of partitions and stay at 8K or 16K clusters respectively.
While writing this I went to the microsoft support page and found this:
"On the typical hard disk partition, the average amount of space that is lost in this manner can be calculated by using the equation (cluster size)/2 * (number of files)."
https://support.microsoft.com/en-us/kb/140365
Doing a quick check with one of my other systems gave the following.
Drive size: 21.9 GB, (Dedicated to games, no OS)
Three partitions at 7.3 GB each (cluster size 4Kb)
34 games installed, totally ca 13.3 GB
Number of files and folders 25323
Very big spread here, from Tomb Raider II with only three files in one folder, to Dark Omen with 6065 files in 137 folders.
2Kb * 25323 is approximately 500 MB lost space at this cluster size.
If I were using the whole drive as one partition the cluster sixe would be 16Kb, hence I would then be losing 4 times as much, around 2 GB and the 34 games would have taken up close to 15 GB.
With a partition larger than 32GB I would lose above 4GB and the same games would be close to 17 GB.
If I don't miscalculated, then typical game installs would take up 25% more space on a partition larger than 32 GB in comparison with the partition < 8GB, while a partition kept between 16-32GB only would lose around 11% against the smallest partition.
So for this 160 GB drive for instance, I'll make a 7 GB OS partition and five partitions around 30 GB each for the best balance. I just wanted to get an approximate picture of the numbers.
