Reply 14440 of 53149, by clueless1
This bad boy showed up today:
1.39 MiB
Going to bench it first on my DOS PC with all 4MB. Then will pull the socketed memory chips out and bench it with 2MB (I don't expect any difference but you never know). Then I will put 1MB into my mainboard to upgrade the onboard CL-GD5428 from 1 to 2MB. Of course, will bench that with 1 and 2 just for completeness sake. Then run fresh benchmarks on my TNT2 M64 and Millennium II. Will use Phil's latest VGA benchmark kit.
Should be a fun weekend. 😀
Reply 14441 of 53149, by debs3759
Just bought these today.
808x motherboard with V20 CPU, 640K memory and 8 8-bit slots.
178.4 KiB
286 motherboard with 287 fpu. Looks like it has had some leakage from the battery so will need some repair work.
171.94 KiB
Finally a Color Graphics card that will work in the V20 board. I don't know much about this, but it looks good 😀
109.02 KiB
Total of $45, courtesy of my drop shipper 😀
Reply 14442 of 53149, by orinoko
debs3759 wrote:
Just bought these today. […]
damn thats a good little find 😀
Now I wanna build up a 286 againnn..!
Reply 14443 of 53149, by stamasd
I have the same card, used in a XT system. At least it looks the same.
I have the card's manual as well. Here's a scanned copy.
https://dl.dropboxusercontent.com/u/107843342 … /CGA%20card.zip
(edit) Damn, now that I took another look at the motherboard, I have the same motherboard also. It's the XT I use the card with. Here's a pic:
https://dl.dropboxusercontent.com/u/107843342 … xt/IMG_0038.jpg
And here's the motherboard manual:
https://dl.dropboxusercontent.com/u/107843342 … motherboard.zip
I have a thread at vcfed.com about this system and some mods I've done to it (I am jh1523 on that site)
http://www.vcfed.org/forum/showthread.php?484 … ebay-components
Mine has a few empty BIOS sockets that I've put to good use. 😀
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 14444 of 53149, by 386_junkie
I'm totally diggin the XT 8-bit hardware just now.
Debs... those are some sweet finds, could I ask... of all the 8-bit graphics cards, you struggled to find one with colour? Are most monochrome?
Once I tie up some loose projects... I will aim to build a nice XT.
Reply 14445 of 53149, by Ozzuneoj
With regards to 8 bit systems, color graphics generally refers to CGA as opposed to EGA or monochrome https://en.m.wikipedia.org/wiki/Color_Graphics_Adapter
Having used an original IBM CGA in my 5150+5153, I found it a bit too limiting for my interests. I couldn't find many CGA (cyan and magenta!) games that I'd be interested in. Bumping up to an EGA card made the computer ten times more interesting, and most CGA games still work fine (aside from Flight Sim... which forces an incompatible mode when it detects EGA). I'm sure if someone had played games with CGA graphics as a kid it'd be different though... I did not. 😀
Reply 14446 of 53149, by PhilsComputerLab
Bought this board from eBay: http://www.asrock.com/mb/VIA/P4VM900-SATA2/
Not cheap at all, but I'd really like to have some PCIe results with 478 processors. I'm finding that the AGP options are just too limited for some of the faster processors.
Asrock always delivers with "oddball" boards like this one 😀
YouTube, Facebook, Website
Reply 14447 of 53149, by havli
Time for something little more recent 😀
Quadro2 MXR (NV11 @ 175 MHz, 32MB SDR @ 183 MHz)
Quadro SDR (NV10 @ 135 MHz, 64MB SDR @ 166 MHz)
Quadro DDR (NV10 @ 135 MHz, 64MB DDR @ 333 MHz)
ELSA Gloria-L88
ELSA Gloria XXL
Reply 14448 of 53149, by brostenen
rkrenicki wrote:
First, a Sound Blaster 16 CT3910 with an OPL3
I have an CT-2910, and it is a good card. Nothing really über awesomme about it.
Other than it's a really solid and useable card. Fits perfect in a 486/Pentium.
Edit...
That motherboard. It looks like an Intel. Not that I say it is one such. It only looks like it.
Reply 14451 of 53149, by Carlos S. M.
There are an even more odd one: http://www.asrock.com/mb/Intel/P4i945GC/
This board uses the Intel 945GC which is a low end chipset for Pentium D/Core 2, but with a Socket 478 CPU, it has PCI-E Graphics as well, but uses Dual Channel DDR2 667 unlike the other Asrock mobo you got (Single channel DDR400). I think the P4i945GC is better than the P4VM900-SATA2 imo, but anyways your choice
The only downside of the P4i945GC is it doesn't support Willamette P4/Celerons, only Northwood and Prescott P4/Celerons
Reply 14452 of 53149, by joe6pack
I bought an Asus P5A board for my SS7 K6-III+ build on ebay only to discover when it arrived:
675.17 KiB
Arghhhhh, it was advertised as a 1.04. The seller has a crap return policy too 😢
As a second attempt, I bought a Soyo SY-5EMA+, which shouldn't have multiple revisions (as far as I can tell).
Reply 14453 of 53149, by SW-SSG
As well, Biostar made a socket 478 board with G31 chipset, supporting DDR2-800. Though again, it doesn't support Willamettes.
http://www.biostar.com.tw/app/en/mb/introduct … on.php?S_ID=502
Reply 14454 of 53149, by rkrenicki
Sorry for my ignorance, but what is the difference between the 1.04 and 1.06 that makes the 1.04 more desirable?
As for returns, It is "not as described", so eBay will force the seller to take it back regardless of the sellers "return policy" (which is a joke term now on eBay). Just open up a case with them.
Reply 14455 of 53149, by hard1k
After 4 years of desperate search I've almost convinced myself that these never actually existed.
But today is a very lucky day!
Seller's pic of a pair of Powerleap PL-P3/Xeon-S adapters, claimed new, stuffed with the corresponding SL6BY:
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 14457 of 53149, by Tetrium
Later versions of that board had issues with running the +'s (they ran very slow I think).
My retro rigs (old topic)
Report spammers here!
Reply 14458 of 53149, by rkrenicki
rkrenicki wrote:
I bought a Roland MPU-401 today that was missing its card, so I also bought all of the parts to build a couple of Lo-Tech MIF-IPC-B cards.
So, the MPU-401 showed up today... it was advertised as "New Old Stock, Missing Box". It showed up in decent physical shape, but obvious signs of use on the connectors and reeking of smoke. I took it all apart and scrubbed the case, and cleaned the board with some contact cleaner. It is much better than it was, but the smell is still kind-of there 🙁 Hopefully it actually works. The Low-tech boards wont be here for a while, so I cannot test it right now.
Reply 14459 of 53149, by senrew
Bought a pair of Apple Radeon 9600 Pro 128MB cards to bring the 2 G5 PowerMacs I got in that lot last week to a decent video level.
http://www.ebay.com/itm/112061755035?_trksid= … K%3AMEBIDX%3AIT
Halcyon: PC Chips M525, P100, 64MB, Millenium 1, Voodoo1, AWE64, DVD, Win95B
