First post, by xstraski
Hi. I have Zida 5DXP REV 3.0 motherboard. It was working OK a year ago.
Yesterday I've decided to build a PC with this motherboard, but have met the problem: COM mouse not working.
If I connect the mouse, AMI BIOS GUI setup shows a cursor with "floating stick" (actually, cursor icon is just plain cursor with static stick when mouse is working), and MS mouse driver for DOS says "Mouse is not present"
If I unplug the mouse, BIOS GUI setup shows no cursor (reason is obvious).
So I see the controller is not dead, it sees the mouse, but for some reason doesn't "talk" with it. A year ago everything was fine. I've tested several mouses, these mouses work on other PCs, and one of these was working with Zida a year ago. COM ports are enabled in BIOS. Your ideas?
Reply 2 of 11, by clueless1
IRQ conflict? Try COM2/IRQ3.
Reply 3 of 11, by Jo22
Is the wiring for that rs232 port alright ?
You know, some i/o cards do use a small header to connect to a cable w/ db9 plug.
Sometimes its pinout is non-standard or you have to flip the plug to make it work.
Sorry, I'm not very good at explaining things, I'm afraid. 😅
I've attached a picture for you.
    35.95 KiB
Reply 4 of 11, by orinoko
Hmm, I ran into a similar problem a while back on a 486 board...
Basically the COM port was wired in such a way that the DB-9 connector was wrong.
I've found that it can either be:
1,2,3,4,5,
6,7,8,9
or
1,3,5,7,9
2,4,6,8
I think...
I could be totally wrong though.
Reply 5 of 11, by Jo22
Me, too. I've got an old internet box which is wired weird.. 😕
1=1,2=2,3=3,..
Reply 6 of 11, by xstraski
+12V and -12V are good from the power supply. I've tried 3 different power supplies.
Motherboard-to-D9 adapter is connected properly, I've tested already both "positions" (with red line on the left and on the right).
Pinouts are pretty standard according to the manual, http://www.elhvb.com/mobokive/archive/Zida/ma … xp/5dxp0310.pdf
Changing from COM A to COM B does nothing.
Reply 8 of 11, by Jepael
Yes, but is the adapter the same it worked with the last time you tried it, or different adapter which might have incompatible pinout?
Reply 11 of 11, by Jo22
There is no standard.
Absolutely. Thankfully the RS232 is very though when it comes to short-circuits (at least in comparison to LPTs)!
So I guess we can only talk about pseudo standard pinouts at best. Sometimes they match, sometimes they don't.
- I once had a modern serial port plate/bracket by Asus that worked in one of my old multi-i/o cards..
