First post, by kanecvr
- Oldbie
Hi guys.
So I had a chance to go to my parent's place and pick up my only socket 4 CPU, and fired up the VIP596P3 board I got from a flea market a couple of weeks ago - and it works! (sort of). The board posts, and I've been able to run speedsys, 3dbench and PCP bench. It performs like a 133MHz AMD 586 in these tests... so... I tried running Quake... problem is I get a "Page Fault at eip=000c928" bla bla error when it's loading the timedemo. As far as I can tell this is memory related...
Thing is, I haven't been able to correctly identify the board. I tought it was made by QDI, but the QDI model is called V5P596P2 and is slightly different - it only had 2 VLB slots, less jumpers and some of the jumpers aren't in the same place as on this board. Here is the stason.org page for the QDI board: http://stason.org/TULARC/pc/motherboards/Q/QD … PENTIUM-VL.html
As you can see it's slightly different - enough so that half of the jumper settings don't match.
Getting to the point - does anyone have a manual for this board? Do you have any idea who made it? Is it possible it's made by QDI but is a different model? What could be causing quake to crash?
