Reply 4840 of 31262, by Kadath
At work I've received a little box of old used hardware, and tons of cables. I've to do a good cleaning of these nice Logitech mouse and keyboard, and maybe start using them in one of my Win9x or XP build:
First comes smiles,
then lies.
Last is gunfire.
Reply 4841 of 31262, by nathan1313
Got most of an IBM XT, model M, and a 386SX motherboard with a few cards for $5. Not bad.
Reply 4842 of 31262, by ElementalChaos
Uh, yeah, you're gonna have to tell us more. 🤣
Not bad. NOT BAD!?!? You may as well have robbed it! Welcome to Vogons by the way, and quite an introduction too!
Pluto, the maxed out Dell Dimension 4100: Pentium III 1400S | 256MB | GeForce4 Ti4200 + Voodoo4 4500 | SB Live! 5.1
Charon, the DOS and early Windows time machine: K6-III+ 600 | 256MB | TNT2 Ultra + Voodoo3 2000 | Audician 32 Plus
Reply 4843 of 31262, by nathan1313
Thanks!!! I'll do some testing tomorrow and see what works! I started collecting in February when my gf got me a dx2-66 for valentines day. Currently at 35(ish) machines and growing. This was the first thing I thought was absolutely post worthy.
Reply 4844 of 31262, by brostenen
Created this little on/off push button thingy for installing AT boards in an ATX case, to make one of them "modern" AT system's with ATX PSU, CF-Card and other modern stuff.
The attachment AT-Push-Button-01.jpg is no longer available
Reply 4845 of 31262, by brostenen
And I tested the FIC 486 VIP IO yet again. Gaming lots of games over a couple of hours, and ran Cachecheck as the last thing.
The attachment Board-Working-Again-01.jpg is no longer available
The attachment Board-Working-Again-02.jpg is no longer available
Reply 4846 of 31262, by stamasd
Trying to make some microdrives work in an old Thinkpad 755CX instead of the original drives. The laptop won't even power up with them attached. Apparently the microdrives I have are 3.3V, and the laptop expects 5V drives. I will have to make a voltage mod. 🙁
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 4847 of 31262, by Tetrium
Been messing with the Vogons wiki lately.
Still trying to think of a way to make it more usable and there's several options I could give a try.
My retro rigs (old topic)
Report spammers here!
Reply 4848 of 31262, by brostenen
Gave my Lucky Star LS486e board, a new voltage regulator. Now it can run 3.xx volt CPU's.
I don't know if it was the regulator that was dead or bad soldering from the maker of the board.
All that does not matter at all, as I can run both AMD 5x86-133 and AMD 486dx2-80 now.
Reply 4849 of 31262, by stamasd
Just finished a large bottle of Duvel. What, it was an old bottle. It should count as retro activity. I'm actually surprised I can still type.
I/O, I/O,
I/O, I/O
Reply 4850 of 31262, by mrau
i'm actually surprised you didn't share, we're all about retro here
Reply 4851 of 31262, by stamasd
Well you weren't here. And I did share, with my wife.
I/O, I/O,
I/O, I/O
Reply 4852 of 31262, by brostenen
Just messed a bit around with an Amd 486dx2-80 setup. Some gaming and watched a couple of old demo's
It has 60ns Ram and a S3-805p VLB card. And I ran superscape on it.
Does 50 fps in superscape sound like an ok result?
Reply 4854 of 31262, by PhilsComputerLab
On 40 MHz FSB, often you need to set a wait state for some aspects of the board. Something to look into? What result do you get for DX2 66?
YouTube, Facebook, Website
Reply 4855 of 31262, by stamasd
Browsing ebay for SCSI stuff. I have the controller, and I think I have a cable or two. I need at least 2 HDDs and terminators. Problem is, most of the drives that I see at the low end of the price range are SCA80, but my target system will be fast-SCSI2 (50pin). Don't need big drives, 9GB will suffice. But I need adapters SCA/fastSCSI and those double the expense. Plus at least one terminator, or possibly two. Haven't made a final decision on the geometry yet. A SCSI CDROM would be bonus. 😀
I/O, I/O,
I/O, I/O
Reply 4856 of 31262, by brostenen
Dont know. The board refuses to run 5volt stable.
Need to look further into why.
I run 1 ws on the VL-bus.
Can't remember the bus settings for mhz.
Reply 4857 of 31262, by luckybob
Pro-tip: use a cable with a built in terminator, or add you own. Drive termination is sketchey at best.
Also, just get a sca80 drive and use an adapter. The small drives are not worth the expense.
Reply 4858 of 31262, by PhilsComputerLab
brostenen wrote:
Dont know. The board refuses to run 5volt stable. Need to look further into why. I run 1 ws on the VL-bus. Can't remember the bu […]
I think my Biostar board, near the VLB slot, has a WS jumper. For 33 MHz bus and lower, no WS is needed. For higher than 33 it is.
Just run that chip at 33 / 66 speed with no WS and see what you get?
Reply 4859 of 31262, by stamasd
I'm not going to rely on drive termination, especially since the ones I'm looking at don't have any. 😀
If I get big drives I won't likely be able to use most of their capacity - this is for a DOS/Win95 system. But that wouldn't matter that much.
Also trying to decide passive vs. active terminators. I'd like active, but the ones I found are twice as expensive as the passive ones. The host adapter is an AHA-1520 so fast-SCSI2 at best, 10MB/s so passive should be OK.
I/O, I/O,
I/O, I/O
