First post, by nio
Hi, does anyone here have original manual for his PVI486-SP3 board? I would be grateful if someone scans it.
I have revision 1.22 and i've not found my manual, maybe there's a chance i still have it somewhere.
I've found scans of pages with instructions for RAM installation at home. I've attached it to the post. For example EDO RAMs are not supported on 1.22.
Another manual I've found was here on vogons and on a japanese ftp site ftp://ftp.tekwind.co.jp/pub/asustw/mb/sock5/. Link to the technical summary is: ftp://ftp.tekwind.co.jp/pub/asustw/mb/sock5/4 … /pvi_486sp3.zip
It lists only chapter 4 Technical summary, which has fortunately plenty of information. I'm not sure which revision it is for.
Second question... what CF card capacity and model usualy works? I've ordered the 40 pin ebay CF adapter with status LEDs.
The setup is running fine, when I've board laying on the ground and graphic card plugged well into PCI slot.
It won't boot when I mount the mainboard and it's metalic plate into the case simply because the PCI card
won't reach into the PCI slot. The case was bought in Slovakia and it has Tesco brand.
I'll later map my wiring of LEDs and other stuff, if someone would be interested, but they are documented in the scanned Technical summary
