First post, by appiah4
While trying to fit a PS/2 keyboard into a PS/2-AT adapter, I tried too hard and broke the plastic pin.. Incidentally, after getting rid of the pin the adapter works like a charm, so I assume the pin was already bent to start with.. My question is, is this pin necessary? Should I bother replacing the PS/2 connector?
Reply 1 of 6, by konc
If you mean the plastic pin in the middle, forget it. It's only there as "guide" so you can connect the plug the right way.
From now on you'll just have to be extra careful and align everything beforehand because with the plastic pin missing it's super easy to bent the actual pins will little force if everything is not in place.
Reply 2 of 6, by appiah4
I have it plugged to an AT adapter and I doubt it will ever get removed so I won't try to change the connector thanks.
Reply 3 of 6, by CapnCrunch53
Any tips for removing the plastic pin from the PS/2 port, by chance? I seem to have broken the tip of it off into one of my systems when I was hastily setting up a retro LAN party for my friends awhile ago >< Unfortunately the pin doesn't stick out at all so I have no idea how to remove it from the port. As it stands, I can't plug any other PS/2 keyboards into that system now since the broken-off pin is in the way.
PCs, Macs, old and new... too much stuff.
Reply 4 of 6, by gdjacobs
A toothpick, a spec of superglue, and a steady hand?
Reply 5 of 6, by Ampera
Get something strong and pointy, and stab the plastic piece, then take it out.
Reply 6 of 6, by appiah4
Well mine got bent teying to plug it in and I was wise enough to renove it before it ultimately broke inside the port but a favorite method is to heat up a metal pin with a lighter and stab the stuck pin with it wait a couple minutes and remove it.
