Asrock 775Dual VSTA & Core4Dual thread
Reply 60 of 735, by A-L-E-X
rod wrote:
Hello. I have a 4CoreDual-SATA2 R2.0 flashed with the latest German modded BIOS and can boot and display properly with 2 graphics cards: Sapphire HD 3850 AGP and PowerColor HD 4350 PCIe 2.0. This was done on Windows 7. No further tests or benchmarks, actually I'm just going to keep the AGP card and discard the PCIe one. I also tried an HD 7750 GDDR5 PCIe 3.0 without success (no boot/no display), so as stated here, later generations of AMD cards don't work on this board/boards (don't know about NVIDIA ones).
At least for me, the real deal for this board would be to load a Marvell chip PCIe 2.0 x2 SATA III controller card. I really doubt it is possible, unless someone here has managed to do so.
Thanks.
The reason your HD 7750 didn't work is that the motherboard does not support anything after PCIe 2.0
Reply 61 of 735, by A-L-E-X
agent_x007 wrote:
You can do BIOS mod for 4GB support : LINK C2E X6800 (without VID mod), will OC to a number between 3,2 - 3,46GHz. Q6600 won't e […]
Q6600 won't even get close to that on this boards (so, if you play games that don't use 4 cores, it sucks compared to X6800).
Q6700 is simply "factory overclocked" Q6600 (usefull, since this MB can't OC locked CPU's far enough).
If you have enough $$$ you can get a QX9650/QX9770 and with VID mod you should be able to overclock it to 3,6GHz 😀
DO NOT BUY 45nm Dual Core CPU's other than E5700 or higher (high multiplier and low FSB are required for optimum OC).
DO NOT BUY 45nm Xeon's or 45nm Quad's with locked multipliers.
Thanks, do you think it is worth it to go from 2 GB RAM to 3.3 GB RAM? I am reading there are stability issues with 4 GB even after using the hacked BIOS 2.20A. I am currently on 2.20
Reply 62 of 735, by agent_x007
@A.L.E.X. If you want to use Windows 7 or late XP games, 3,5GB of RAM is useful.
If not, 2GB will be fine.
Why you want to buy a new GPU for this setup ?
Buy used GTX 460 or GTX 285/HD 5850 (first and last one give you DX11 support).
You can't force a PCI-e GPU to allocate X ammount of system RAM to graphics card.
PCI-e always "locks" fixed value of 256MB of RAM per GPU on any given card (if MB has 32-bit adress limit).
Dedicated RAM is only for AGP port only.
PCI-e will use whatever is necessary.
GPU usage isn't a problem for longevity.
Temperatures for GPU and it's VRM at those high usage levels however an be dangerous (if too high).
Check GPU temps in GPU-z.
Reply 63 of 735, by A-L-E-X
agent_x007 wrote:
@A.L.E.X. If you want to use Windows 7 or late XP games, 3,5GB of RAM is useful. If not, 2GB will be fine. […]
Thanks, I was considering getting your GTX 580
https://www.amazon.com/GeForce-Superclocked-M … s&sortBy=recent
Found it used on Amazon. Is that a better buy than the GT 730? I saw your scores on 3DMark, but did not see 06 scores...... on 06 with my current set up I get around 9,500 marks.
GTX 580 is many levels higher on the Hierarchy Chart I posted before but is only 1.5 GB VRAM. Should I get that used for its faster speed (or does that even matter with this board since it's a PCI-e x4 board) or get the GT 730 new since it has more video memory? Which would run cooler and have a lower usage percentage?
What is VRM? I run eVga Precision and find that my temperatures are around 85C and almost the entire 640 MB video memory is being used.
So according to the above, I definitely need a video card with more memory, since no more than 256mb of memory additional to what is on the video card can be allocated to memory usage? So that would be 640+256=896MB total memory for graphics?
Pretty much any PCIE 2.0 video card will work on this board? I have BIOS 2.20 (not the hacked version.) I am a bit leery of going to 4 GB because I read there are stability issues with it and it took me awhile to get my timings right even with the 2 GB (2x1 GB) Crucial memory I already have- I had to slow down DDR2-667 to DDR2-533 because my PC would occasionally automatically shut down. Do you recommend I get the DDR2-667 Crucial (2x2GB) kit? I found it for $20 on Amazon (though I don't know if this is genuine Crucial memory like the $60 kit I found on Newegg.
https://www.amazon.com/CRUCIAL-CT2KIT25664AA6 … A45N3CEH3AV66CC
I am going to install Windows 10 Home x32 on this computer and try to run a dual boot XP/10 system. Should I get the memory upgrade for that and will I need to make any BIOS changes for it to work with 10 Home (and will my current video card as well as the above cards we discussed as upgrades also work with it?) Thanks!
Reply 64 of 735, by Asomodai
Just managed to get hold of a 4CoreDual-VSTA
Reply 65 of 735, by agent_x007
3DMark 06 :
With OC'ed QX9770 : LINK
With OC'ed E5800 : LINK
Keep in mind, 3DMark's 01-06 LOVE CPU speed at GTX 580 performance level.
4GB of VRAM is meaningless with GT 730, that card will "drown" before actually using 2GB of VRAM (drown in data, or "grind to a halt" FPS wise).
PCI-e x4 will slow down GTX 580 or Radon HD 5870 on this MB, but how much... I can't be sure.
VRM is power delivering stage on PCB (MOSFETs, chokes, capacitors, drivers, etc.), since they must deliver power they will get VERY hot when GPU is under full load.
Overheatig VRM will die fast and kill GPU with it.
256MB is only reserved by BIOS.
Windows can alocate to PCI-e cards as much memory as it wants from virtual memory pool (ie.VRAM + RAM + Page File).
Simply put : Ultimate limit for capacity of VRAM is Page File size (which is on hard drive if not disabled/moved to RamDisk-type storage).
Problem with it is it's speed (GPU's need very high bandwidth memory to function at nominal speeds, going over VRAM capacity = slow down to few FPS tops).
533MHz DRAM Frequency works best on this motherboard.
If it's still too much, simply use Flexibility option (which can help in high FSB overclocking).
I can't recommend a kit that I didn't use personally, but logic dictates that all 2GB DDR2 RAM sticks should work in all DDR2 based motherboards that support 4GB of RAM while having two slots.
Windows 10 compatibility :
This board will work on Win 10, drivers for GPU's can be found on Nvidia's website.
Reply 66 of 735, by vetz
I havent had any issues with 4GB of RAM in this motherboard, so go for it. You'll need it if you're going to use Windows 7 or Windows 10.
As agent_x007 said, GTX 580 is the fastest card you can use in these boards. The PCI-e x4 will slow down quite much! If you take the same CPU and GPU and put it in another board you'll see alot better results. You can see that on the benchmark results agent_x007 have provided earlier in this thead where a HD3850 AGP almost gets the same result as a GTX580 in 3DMark. That is also the results I've been getting. What helps is to overclock the PCI-e bus as much as you can. Having a more powerful card also allows you to get higher AA and AF without much performance loss. For some reason AA and AF settings does not seem to be as bottlenecked by the 4x bus.
Remember the settings below if you're going to run Windows 10 and/or newer graphics cards:
In Windows 10, there can be an issue installing drivers for a PCI-Express, but just run the following command and you're good to […]
In Windows 10, there can be an issue installing drivers for a PCI-Express, but just run the following command and you're good to go:
    Open the start menu and type cmd in the search box
Right-click on cmd.exe and select Run as administrator
In the command window, type bcdedit /set pciexpress forcedisable
Reboot your computer
In any Windows version, if you have problems installing the PCI Express graphic card drivers (I had to do this with the GTX480), go to BIOS and change the following settings:
PCIE Downstream Pipeline to DISABLE (Auto is default)
PCIE VC1 Request Queue to DISABLE (Auto is default)
Reply 67 of 735, by Reputator
FGB wrote:
feipoa wrote:
Were these ASRock boards really a hunk of junk? I am using an ASRock 939Dual-SATA2 as my main computer now. The gaming performance benchmarks from Anandtech were pretty good. Anandtech reviews seemed pretty decent too. It uses the ULi chipset and also has AGP + PCI-E. It has this funny AGP-like AM2 CPU slot, but I use a standard socket 939 Opteron 180. I had to recap the motherboard recently as all the caps were starting to bulge one by one.
The 939Dual-SATA2 is a kind of a cult board. It was very popular and reliable and also a decent performer. Later drivers and BIOS updates overcame the early SATA2-problems.
Love it. Also a great board to test GFXs.
It is my current XP board, and yep, it's fantastic. I also had to replace the caps around the CPU socket because they were leaky, but since doing that it's rock solid, and even overclocks amazingly well considering you can't raise the VCORE.
It's really the only board to provide full bandwidth PCIe and AGP while still maintaining great compatibility. VIA PT880 Pro/Ultra boards are nice and you get more CPU performance, but running PCIe cards with only 1GB/s of bandwidth really hurts.
https://www.youtube.com/c/PixelPipes
Graphics Card Database
Reply 68 of 735, by A-L-E-X
agent_x007 wrote:
3DMark 06 : With OC'ed QX9770 : LINK With OC'ed E5800 : LINK Keep in mind, 3DMark's 01-06 LOVE CPU speed at GTX 580 performance […]
3DMark 06 :
Wow, those results are similar to the HD 3850 AGP?
Thanks, I was wondering why the GT 730 is rated so low (five rungs below my current card!). It appears that it uses a slower form of memory- DDR3 vs GDDR3, which is what I have right now. How was the GTX 580 with respect to overheating and power supply usage? I am using a 700W OCZ Power Supply. My Corsair 550 Watt PSU was not enough and died within 2 years of usage, but my 700W Modular OCZ PSU seems to be working well.
I see some of what you're talking about with high GPU usage already with the board I currently have. I had to downclock the GPU because temps were over 100C at stock speeds and 95% GPU usage. That's why I am worried about a GTX 580 heating up even more- my current GPU uses 150W of power, I read that the GTX 580 uses 250W of power and the GT 730 only uses 49W of power.
I have set 8 GB from my hard drive as virtual memory, but I notice that when the page file is being used, the system grinds to a halt. I have to wait while the system moves swaps memory back and forth (I use the CleanMem minimonitor to measure this.) The question is is the 4 GB DDR3 of the GT 730 better than using 640 MB GDDR3 of the current video card plus 2 GB DDR2 RAM plus 8 GB of virtual memory? Or should I just go the GTX 580 route and not worry about it heating up more than my current board does (which already heats up a lot.) Will the GPU usage be less with the GTX 580 than it is with my current board since it's a more powerful board?
Have you used 4 GB RAM on your board and not experienced any stability issues?
Thanks about Win 10 compatibility, but I was specifically asking about any BIOS settings that I should set differently from what I set them for Win XP. I read somewhere that the graphics drivers won't load properly if I don't change the BIOS settings.
Reply 69 of 735, by A-L-E-X
vetz wrote:
I havent had any issues with 4GB of RAM in this motherboard, so go for it. You'll need it if you're going to use Windows 7 or Wi […]
Do you think I should install the 32 bit version of Win 10 since that seems to require a lower memory footprint?
Thanks, how is the GTX 580 in terms of overheating? I hope my 700W OCZ Modular PSU will be enough for it- my 550W Corsair PSU was not enough for my 8800 GTS 640MB 112 SP. How does one overclock the PCI-e bus and does this overheat and shorten the life of the GPU?
I think better results with AA and AF are because you are now putting the GPU to work thus reducing the overhead, which brings the bus more in line with faster PCI-e slots. In other words, AAxAF reduces the "ceiling" for the faster slots too so everything becomes more equalized.
Thanks for that, I read that Win 10 requires BIOS settings changes from Win XP even though I had already changed some BIOS settings to get the drivers to work with XP. Are those the only three settings to look for? I hope PCI-e forced disable does not disable the PCI-e slot 🤣!
Reply 70 of 735, by A-L-E-X
Here's a weird thing, I just searched for all 3DMark scores using the Q6600 as the CPU and then selected for 8800GTS, 8800GTX and GTX 580, and all had around the same top scores- 20,000 Marks! GT 730 was somewhat lower.
http://www.3dmark.com/search#/?mode=advanced& … 0&cpuName=Intel Core 2 Quad Processor Q6600&gpuName=NVIDIA GeForce 8800 GTS 320MB/640MB
RESULTS3438 RESULTS FOUND. DISPLAYING 965 RESULTS
216533DMark06 (1.1) by user#1056451February 20 2008
mmsiecom
1Intel Core 2 Quad Processor Q6600 (3,148 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTS 320MB/640MB (0 MHz)Add to compare
206093DMark06 (1.1) by M3AceJuly 19 2008
///Mpower
2Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTS 320MB/640MB (702 MHz)Add to compare
201423DMark06 (1.1) by user#1465729January 14 2008
FSB Kearu@hardwareoc.at - 2x8800GTS - Core2Quad 6600
3Intel Core 2 Quad Processor Q6600 (3,937 MHz)Details
200783DMark06 (1.1) by user#6301032December 15 2007
ChinStrap - OCForums -
4Intel Core 2 Quad Processor Q6600 (4,166 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTS 320MB/640MB (676 MHz)
http://www.3dmark.com/search#/?mode=advanced& … 0&cpuName=Intel Core 2 Quad Processor Q6600&gpuName=NVIDIA GeForce 8800 GTX
RESULTS3776 RESULTS FOUND. DISPLAYING 986 RESULTS
215733DMark06 (1.2)November 3 2011
1Intel Core 2 Quad Processor Q6600 (2,400 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTX (576 MHz)Add to compare
212883DMark06 (1.1) by user#2751702June 26 2008
Q6600+8800GTXx2 XP32bit
2Intel Core 2 Quad Processor Q6600 (4,161 MHz)Details
Pineview Industries Ltd. NVIDIA GeForce 8800 GTX (0 MHz)Add to compare
209703DMark06 (1.1) by user#3018697August 16 2008
Untitled
3Intel Core 2 Quad Processor Q6600 (4,048 MHz)Details
Asustek Computer, Inc. NVIDIA GeForce 8800 GTX (660 MHz)Add to compare
208703DMark06 (1.1) by CraptacularOne-2November 25 2007
Agent Blue
4Intel Core 2 Quad Processor Q6600 (4,027 MHz)Details
Pineview Industries Ltd. NVIDIA GeForce 8800 GTX (661 MHz)Add to compare
208623DMark06 (1.1) by user#11786791April 20 2008
3.98GHz
5Intel Core 2 Quad Processor Q6600 (3,978 MHz)Details
BFG Technologies, Inc. NVIDIA GeForce 8800 GTX (108 MHz)Add to compare
208283DMark06 (1.1) by user#3705306April 9 2008
peQs
6Intel Core 2 Quad Processor Q6600 (4,038 MHz)Details
Pineview Industries Ltd. NVIDIA GeForce 8800 GTX (660 MHz)Add to compare
208263DMark06 (1.1) by SuLac0March 23 2008
Untitled
7Intel Core 2 Quad Processor Q6600 (3,900 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTX (108 MHz)Add to compare
208093DMark06 (1.1) by creative2kApril 25 2008
First Test
8Intel Core 2 Quad Processor Q6600 (4,125 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTX (108 MHz)Add to compare
207993DMark06 (1.1) by BuddatechMay 5 2008
750i FTW 8800GTXsli@648/1550/2016
9Intel Core 2 Quad Processor Q6600 (4,005 MHz)Details
207963DMark06 (1.1) by user#11802384February 26 2008
Jimm's Pc-Store Fastest PC
10Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTX (650 MHz)Add to compare
207753DMark06 (1.1) by BuddatechMay 5 2008
750i FTW 8800GTX_2@648/1500/2016
11Intel Core 2 Quad Processor Q6600 (4,005 MHz)Details
206283DMark06 (1.1) by user#2751702March 6 2008
Q6600 + 8800GTX SLI
12Intel Core 2 Quad Processor Q6600 (4,073 MHz)Details
Pineview Industries Ltd. NVIDIA GeForce 8800 GTX (630 MHz)Add to compare
205743DMark06 (1.1) by user#11795622April 7 2008
aForce
13Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
205323DMark06 (1.1) by user#2751702March 5 2008
Q6600 + 8800GTX SLI
14Intel Core 2 Quad Processor Q6600 (4,059 MHz)Details
203703DMark06 (1.1) by SDhydroFebruary 18 2008
Untitled
15Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTX (0 MHz)Add to compare
203363DMark06 (1.1) by user#3705306April 12 2008
Untitled
16Intel Core 2 Quad Processor Q6600 (4,027 MHz)Details
203103DMark06 (1.1) by user#11883383October 11 2008
Untitled
17Intel Core 2 Quad Processor Q6600 (3,904 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTX (658 MHz)Add to compare
203073DMark06 (1.1) by user#11883383October 11 2008
Untitled
18Intel Core 2 Quad Processor Q6600 (3,904 MHz)Details
202473DMark06 (1.1) by user#11883383October 9 2008
Untitled
19Intel Core 2 Quad Processor Q6600 (3,904 MHz)Details
202063DMark06 (1.1) by user#3018697December 27 2007
Untitled
20Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
Asustek Computer, Inc. NVIDIA GeForce 8800 GTX (108 MHz)Add to compare
201823DMark06 (1.1) by user#3018697December 26 2007
Untitled
21Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
201483DMark06 (1.1) by SuLac0August 30 2007
SuLac0
22Intel Core 2 Quad Processor Q6600 (4,003 MHz)Details
200723DMark06 (1.1) by UhudlerNovember 3 2007
Q6600@3,8 + 8800GTX SLI 675/1566/1080
23Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
Asustek Computer, Inc. NVIDIA GeForce 8800 GTX (666 MHz)Add to compare
200463DMark06 (1.1) by user#11883383October 9 2008
Untitled
24Intel Core 2 Quad Processor Q6600 (3,892 MHz)Details
200063DMark06 (1.1) by user#11116083January 31 2008
Q66@3,901GHz_4gbCorsair@1060MHz_2x88gtx@621/1458/1053_169.28_xp_EVGA_122_ck_nf68_a1_d00
25Intel Core 2 Quad Processor Q6600 (3,900 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTX (622 MHz)Add to compare
199843DMark06 (1.1) by SDhydroFebruary 10 2008
Untitled
26Intel Core 2 Quad Processor Q6600 (3,979 MHz)Details
198763DMark06 (1.1) by user#2153747May 5 2008
deathstar 5
27Intel Core 2 Quad Processor Q6600 (3,882 MHz)Details
198453DMark06 (1.1) by SDhydroFebruary 9 2008
Untitled
28Intel Core 2 Quad Processor Q6600 (3,960 MHz)Details
198263DMark06 (1.1) by user#11116083January 30 2008
Q66@3,869GHz_4gbCorsair@1060MHz_2x88gtx@621/1458/1053_169.28_xp_EVGA_122_ck_nf68_a1_d00
29Intel Core 2 Quad Processor Q6600 (3,869 MHz)Details
http://www.3dmark.com/search#/?mode=advanced& … 0&cpuName=Intel Core 2 Quad Processor Q6600&gpuName=NVIDIA GeForce GT 730
RESULTS39 RESULTS FOUND. DISPLAYING 5 RESULTS
111673DMark06 (1.2)December 16 2016
Asustek Computer, Inc. NVIDIA GeForce GT 730 (902 MHz)Add to compare
92463DMark06 (1.2)August 18 2015
2Intel Core 2 Quad Processor Q6600 (2,394 MHz)Details
Palit Microsystems Ltd. NVIDIA GeForce GT 730 (1,102 MHz)Add to compare
88473DMark06 (1.2)February 22 2016
3Intel Core 2 Quad Processor Q6600 (2,400 MHz)Details
Micro-Star International Co ., Ltd. NVIDIA GeForce GT 730 (1,006 MHz)Add to compare
81703DMark06 (1.2)April 30 2015
4Intel Core 2 Quad Processor Q6600 (2,394 MHz)Details
Palit Microsystems Ltd. NVIDIA GeForce GT 730 (902 MHz)Add to compare
81653DMark06 (1.2)July 16 2015
5Intel Core 2 Quad Processor Q6600 (2,394 MHz)Details
http://www.3dmark.com/search#/?mode=advanced& … 0&cpuName=Intel Core 2 Quad Processor Q6600&gpuName=NVIDIA GeForce GTX 580
QUICK FILTERS
Number of GPUs Show only valid results ?
RESULTS433 RESULTS FOUND. DISPLAYING 373 RESULTS
205583DMark06 (1.2)November 15 2012
1Intel Core 2 Quad Processor Q6600 (3,807 MHz)Details
PNY Technologies, Inc. NVIDIA GeForce GTX 580 (772 MHz)Add to compare
200733DMark06 (1.2)February 11 2011
2Intel Core 2 Quad Processor Q6600 (4,059 MHz)Details
Giga-Byte Technology Co., Ltd. NVIDIA GeForce GTX 580 (830 MHz)Add to compare
199643DMark06 (1.2)September 5 2012
3Intel Core 2 Quad Processor Q6600 (3,906 MHz)Details
Asustek Computer, Inc. NVIDIA GeForce GTX 580 (950 MHz)Add to compare
198473DMark06 (1.2)February 13 2011
4Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
Giga-Byte Technology Co., Ltd. NVIDIA GeForce GTX 580 (850 MHz)Add to compare
198363DMark06 (1.2)December 30 2011
5Intel Core 2 Quad Processor Q6600 (3,615 MHz)Details
NVidia Corporation NVIDIA GeForce GTX 580 (0 MHz)Add to compare
6Intel Core 2 Quad Processor Q6600 (3,615 MHz)Details
7Intel Core 2 Quad Processor Q6600 (3,615 MHz)Details
197493DMark06 (1.2)February 12 2011
8Intel Core 2 Quad Processor Q6600 (4,059 MHz)Details
Giga-Byte Technology Co., Ltd. NVIDIA GeForce GTX 580 (835 MHz)Add to compare
197343DMark06 (1.2)February 13 2011
9Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
Giga-Byte Technology Co., Ltd. NVIDIA GeForce GTX 580 (785 MHz)Add to compare
196583DMark06 (1.2)February 3 2012
10Intel Core 2 Quad Processor Q6600 (4,162 MHz)Details
Micro-Star International Co ., Ltd. NVIDIA GeForce GTX 580 (0 MHz)Add to compare
195093DMark06 (1.2)February 3 2012
11Intel Core 2 Quad Processor Q6600 (4,162 MHz)Details
193653DMark06 (1.2)April 29 2011
12Intel Core 2 Quad Processor Q6600 (3,599 MHz)Details
Micro-Star International Co ., Ltd. NVIDIA GeForce GTX 580 (800 MHz)Add to compare
192783DMark06 (1.2) by shenmue2November 18 2012
13Intel Core 2 Quad Processor Q6600 (3,599 MHz)Details
EVGA Corporation NVIDIA GeForce GTX 580 (772 MHz)Add to compare
190853DMark06 (1.2) by FraggamanDecember 4 2012
14Intel Core 2 Quad Processor Q6600 (3,402 MHz)Details
190153DMark06 (1.2)March 20 2011
Gainward GmbH NVIDIA GeForce GTX 580 (783 MHz)Add to compare
189913DMark06 (1.2)September 17 2011
http://www.3dmark.com/search#/?mode=advanced& … 0&cpuName=Intel Core 2 Quad Processor Q6600&gpuName=NVIDIA GeForce 8800 GTS 512MB
RESULTS3423 RESULTS FOUND. DISPLAYING 978 RESULTS
222833DMark06 (1.1) by user#9301389June 13 2008
Untitled
1Intel Core 2 Quad Processor Q6600 (4,281 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTS 512MB (777 MHz)Add to compare
219083DMark06 (1.1) by user#9301389June 11 2008
Untitled
2Intel Core 2 Quad Processor Q6600 (4,250 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTS 512MB (790 MHz)Add to compare
218243DMark06 (1.1) by user#9301389June 10 2008
Untitled
3Intel Core 2 Quad Processor Q6600 (4,240 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTS 512MB (785 MHz)Add to compare
217963DMark06 (1.1) by user#9301389June 10 2008
Untitled
4Intel Core 2 Quad Processor Q6600 (4,225 MHz)Details
217843DMark06 (1.1) by user#10032189January 16 2008
Untitled
5Intel Core 2 Quad Processor Q6600 (4,251 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTS 512MB (0 MHz)Add to compare
216023DMark06 (1.1) by user#10032189January 16 2008
Untitled
6Intel Core 2 Quad Processor Q6600 (4,240 MHz)Details
214783DMark06 (1.1) by user#10032189January 14 2008
Untitled
7Intel Core 2 Quad Processor Q6600 (4,184 MHz)Details
214333DMark06 (1.1) by user#10032189January 16 2008
Untitled
8Intel Core 2 Quad Processor Q6600 (4,240 MHz)Details
213953DMark06 (1.1) by user#9301389June 5 2008
Untitled
9Intel Core 2 Quad Processor Q6600 (4,162 MHz)Details
213343DMark06 (1.1) by user#10032189January 13 2008
Untitled
10Intel Core 2 Quad Processor Q6600 (4,184 MHz)Details
212143DMark06 (1.1) by user#9301389June 5 2008
Untitled
11Intel Core 2 Quad Processor Q6600 (4,151 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTS 512MB (773 MHz)Add to compare
211353DMark06 (1.1) by user#11722309August 26 2008
UNDERSTANDING Striker II X
12Intel Core 2 Quad Processor Q6600 (4,005 MHz)Details
BFG Technologies, Inc. NVIDIA GeForce 8800 GTS 512MB (0 MHz)Add to compare
211273DMark06 (1.1) by killerhzJune 29 2008
killerhz
EVGA Corporation NVIDIA GeForce 8800 GTS 512MB (0 MHz)Add to compare
killerhz
14Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
210983DMark06 (1.1) by user#9301389June 5 2008
Untitled
15Intel Core 2 Quad Processor Q6600 (4,101 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTS 512MB (753 MHz)Add to compare
210553DMark06 (1.1) by user#10032189January 12 2008
Untitled
16Intel Core 2 Quad Processor Q6600 (4,162 MHz)Details
209883DMark06 (1.1) by user#11792437February 11 2008
Untitled
17Intel Core 2 Quad Processor Q6600 (4,003 MHz)Details
209183DMark06 (1.1) by killerhzJune 29 2008
killerhz
18Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
208603DMark06 (1.1)March 12 2008
761/1111 | 1772QDR
19Intel Core 2 Quad Processor Q6600 (3,984 MHz)Details
207933DMark06 (1.1)March 11 2008
764/111 1767QDR
20Intel Core 2 Quad Processor Q6600 (3,975 MHz)Details
207883DMark06 (1.1) by user#9301389May 28 2008
Untitled
21Intel Core 2 Quad Processor Q6600 (4,101 MHz)Details
207803DMark06 (1.1) by Primalfear-2January 5 2008
Untitled
22Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
206963DMark06 (1.1) by user#270931March 13 2008
Untitled
23Intel Core 2 Quad Processor Q6600 (4,005 MHz)Details
206883DMark06 (1.1) by PunscherMarch 26 2008
W4nst3n@ 8800 GTS 512 SLi Overclocking Session
24Intel Core 2 Quad Processor Q6600 (3,903 MHz)Details
206083DMark06 (1.1) by killerhzMarch 30 2008
killerhz
25Intel Core 2 Quad Processor Q6600 (4,000 MHz)Details
205653DMark06 (1.1)March 7 2008
Untitled
26Intel Core 2 Quad Processor Q6600 (3,903 MHz)Details
205633DMark06 (1.1) by user#10806567January 22 2008
Untitled
27Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
205503DMark06 (1.1) by ShadowjumpDecember 23 2007
Untitled
28Intel Core 2 Quad Processor Q6600 (4,003 MHz)Details
Pineview Industries Ltd. NVIDIA GeForce 8800 GTS 512MB (0 MHz)Add to compare
205383DMark06 (1.1) by Primalfear-2January 5 2008
Untitled
29Intel Core 2 Quad Processor Q6600 (4,000 MHz)Details
205373DMark06 (1.1) by user#10032189January 12 2008
Untitled
30Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
205363DMark06 (1.1)March 7 2008
GTS SLI - 758/1081
31Intel Core 2 Quad Processor Q6600 (3,903 MHz)Details
205303DMark06 (1.1) by user#10806567January 22 2008
Untitled
32Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
204923DMark06 (1.1) by user#11793104May 10 2008
Untitled
33Intel Core 2 Quad Processor Q6600 (4,005 MHz)Details
203943DMark06 (1.1) by user#11722309May 26 2008
UNDERSTANDING UNLEASHED
34Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
203903DMark06 (1.1) by PunscherMarch 20 2008
Punscher OC @ 3,85 Ghz @ POV 8800 512 SLI
35Intel Core 2 Quad Processor Q6600 (3,856 MHz)Details
203863DMark06 (1.1) by DancopJune 12 2008
XP 32bit
36Intel Core 2 Quad Processor Q6600 (3,839 MHz)Details
203813DMark06 (1.1) by user#3309085April 23 2008
Eclipse @ 3.83Ghz 4GB DDR1066 (850,4,4,3,12,1T) 8800GTS 750/1004 SLI
37Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
Micro-Star International Co ., Ltd. NVIDIA GeForce 8800 GTS 512MB (0 MHz)Add to compare
203693DMark06 (1.1) by killerhzFebruary 25 2008
killerhz
38Intel Core 2 Quad Processor Q6600 (4,000 MHz)Details
203413DMark06 (1.1) by user#4182304April 10 2008
Jimm's Pc-Store Fastest Pc
39Intel Core 2 Quad Processor Q6600 (4,099 MHz)Details
Asustek Computer, Inc. NVIDIA GeForce 8800 GTS 512MB (0 MHz)Add to compare
203393DMark06 (1.1) by SirMasterJune 16 2008
Q6600 3.8Ghz 8800GTS 512 SLi (OC)
40Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
202853DMark06 (1.1) by user#3749252March 3 2008
Losmile
41Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTS 512MB (805 MHz)Add to compare
202833DMark06 (1.1)February 11 2008
Untitled
42Intel Core 2 Quad Processor Q6600 (4,275 MHz)Details
202773DMark06 (1.1) by FirstBlood-2March 7 2008
4.0ghz Benchmark only
43Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
202273DMark06 (1.1) by user#3757961February 1 2008
3900mhz 810/2100 sli
44Intel Core 2 Quad Processor Q6600 (3,900 MHz)Details
202033DMark06 (1.1) by wcrfJune 20 2008
Q6600@3,85GHz, vgas 765/1940/1050
45Intel Core 2 Quad Processor Q6600 (3,850 MHz)Details
202023DMark06 (1.1) by Stillbirth666January 5 2008
Untitled
46Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
201353DMark06 (1.1) by user#9301389April 17 2008
Untitled
47Intel Core 2 Quad Processor Q6600 (4,104 MHz)Details
201353DMark06 (1.1) by user#9301389April 19 2008
Untitled
48Intel Core 2 Quad Processor Q6600 (4,101 MHz)Details
201243DMark06 (1.1) by user#10032189January 11 2008
Untitled
49Intel Core 2 Quad Processor Q6600 (3,869 MHz)Details
200963DMark06 (1.1) by wcrfMay 13 2008
Q6600@3,825GHz, vgas 760/1940/1050
50Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
200463DMark06 (1.1) by user#3683332February 4 2008
ncsa: Q6600- 425x9 H20 / 8800 G92 SLI Air / eVGA 780i
51Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
200273DMark06 (1.1) by user#3683332February 7 2008
52Intel Core 2 Quad Processor Q6600 (3,825 MHz)Details
200053DMark06 (1.1) by user#11823781April 11 2008
8800GTS 512 SLI
53Intel Core 2 Quad Processor Q6600 (3,754 MHz)Details
200003DMark06 (1.1) by user#11847239June 21 2008
provan
54Intel Core 2 Quad Processor Q6600 (4,106 MHz)Details
EVGA Corporation NVIDIA GeForce 8800 GTS 512MB (810 MHz)Add to compare
199753DMark06 (1.1) by Primalfear-2January 5 2008
Untitled
55Intel Core 2 Quad Processor Q6600 (3,900 MHz)Details
199353DMark06 (1.1) by user#10806567January 22 2008
Untitled
56Intel Core 2 Quad Processor Q6600 (3,900 MHz)Details
198603DMark06 (1.1) by user#11385840March 16 2008
Untitled
57Intel Core 2 Quad Processor Q6600 (3,735 MHz)Details
198153DMark06 (1.1)January 26 2008
Untitled
58Intel Core 2 Quad Processor Q6600 (4,005 MHz)Details
198103DMark06 (1.1) by user#11722309January 16 2009
Yahyaue 790i FTW
59Intel Core 2 Quad Processor Q6600 (3,938 MHz)Details
BFG Technologies, Inc. NVIDIA GeForce 8800 GTS 512MB (774 MHz)Add to compare
197903DMark06 (1.1) by user#3749252March 3 2008
Untitled
60Intel Core 2 Quad Processor Q6600 (3,678 MHz)Details
197903DMark06 (1.1) by user#11825515March 30 2008
8800GTS SLI
61Intel Core 2 Quad Processor Q6600 (4,162 MHz)Details
197533DMark06 (1.1)January 25 2008
Untitled
62Intel Core 2 Quad Processor Q6600 (4,005 MHz)Details
196293DMark06 (1.1) by user#3749252March 3 2008
Untitled
63Intel Core 2 Quad Processor Q6600 (3,656 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTS 512MB (800 MHz)Add to compare
195933DMark06 (1.1) by user#11813258May 6 2008
Untitled
64Intel Core 2 Quad Processor Q6600 (3,780 MHz)Details
195723DMark06 (1.1) by user#9301389June 20 2008
Untitled
65Intel Core 2 Quad Processor Q6600 (3,600 MHz)Details
195623DMark06 (1.1) by killerhzFebruary 21 2008
killerhz
66Intel Core 2 Quad Processor Q6600 (3,800 MHz)Details
195353DMark06 (1.1) by user#3749252March 3 2008
Untitled
67Intel Core 2 Quad Processor Q6600 (3,600 MHz)Details
195183DMark06 (1.1) by user#11847239May 3 2008
My Best
68Intel Core 2 Quad Processor Q6600 (4,050 MHz)Details
194673DMark06 (1.1) by user#11888018September 6 2008
Untitled
69Intel Core 2 Quad Processor Q6600 (4,319 MHz)Details
194523DMark06 (1.1) by user#11813258March 19 2008
Untitled
70Intel Core 2 Quad Processor Q6600 (3,672 MHz)Details
194293DMark06 (1.1) by user#1586171March 27 2008
Untitled
71Intel Core 2 Quad Processor Q6600 (3,600 MHz)Details
Reply 71 of 735, by A-L-E-X
I looked at their 3D Vantage scores and they're pretty similar too. Based on this, I really should go for the GTX 580 but I'm wondering if I need a new PSU. My 700W PSU has 50A divided equally between two 12V rails. I also have 3 80mm Vantec tornado fans, 3 ODD and 8 USB ports, a sound card, a pci slot cooler and a gigabit ethernet card in my pci slots.
RESULTS7 RESULTS FOUND. DISPLAYING 3 RESULTS
200513DMark Vantage Entry (1.1) by DjRavixApril 20 2012
1Intel Core 2 Quad Processor Q6600 (2,997 MHz)Details
NVidia Corporation NVIDIA GeForce 8800 GTS 512MB (750 MHz)Add to compare
194193DMark Vantage Entry (1.1)January 20 2012
Asustek Computer, Inc. NVIDIA GeForce 8800 GTS 512MB (650 MHz)Add to compare
3Intel Core 2 Quad Processor Q6600 (2,394 MHz)Details
RESULTS1 RESULTS FOUND. DISPLAYING 1 RESULTS
240673DMark Vantage Entry (1.0) by TuxphobosMay 12 2011
Q6600-OC3.0 GTX580
1Intel Core 2 Quad Processor Q6600 (3,000 MHz)Details
Reply 72 of 735, by agent_x007
I own MSI's GTX 580 Lightning - it doesn't overheat : LINK 😉
But reference model of GTX 580 is kinda toasty (not as much as GTX 470/480 tho).
700W OCZ shouldn't have problem with it.
Keep in mind, there is always Radeon 5870 which is little less hot than your 8800 GTS ("112SP" 90nm).
3DMark 06 is a CPU heavy test (when you put a DX10+ GPU inside).
Still, GPU's scale quite nicely on it (4CoreDual boards need big L2 caches in CPU to hide pretty crappy IMC) :
3DMark's 06 HD 5870 valid link (with OC'ed Q9770) : LINK
As for HD 3850 vs. GTX 580 vs. 5870... 3850 doesn't stand a chance/"get's rekt" in higher resolutions or with AA/AF (in low details they are all the same - PCI-e x4 and slow RAM subsystem, it's only VIA).
In Crysis under Win XP, HD 5870 is best out of those three.
GTX 580 will be better under Windows 7 or newer, and in modern games (5870 doesn't have updated drivers).
Crysis "High" Full HD (with OC'ed QX9770, avg. is based on two last runs out of three) :
3850 : Avg. ~32,59FPS
GTX 580 : Avg. 64,41FPS
HD 5870 : Avg. 81,67FPS
Reply 73 of 735, by A-L-E-X
Thanks, I used a few different power calculators to come up with 650W/40A 12V rail being my requirements, so the 700W/50A 12V rail PSU I have should be just fine 😀
You have quite a collection of GPU's there- do you think I could still find the Radeon 5870 somewhere? And do you find 1 GB of VRAM to be enough?
I found a few on Amazon
https://www.amazon.com/s/ref=sr_st_price-asc- … =price-asc-rank
It's three rungs below the GTX 580 on Tom's Hardware's Hierarchy chart.
http://www.tomshardware.com/reviews/gpu-hierarchy,4388.html
Does it have lower power requirements than the GTX 580 and does it run cooler than that card?
I see the 7870 is pretty reasonably priced too- that won't work on this board will it?
Thanks for the link to your GTX 580- how does it compare to EVGA's copy?
https://www.amazon.com/gp/offer-listing/B004B … &condition=used
One other thing about the memory- how is the 3.3 GB distributed- is it 2 GB from one stick and 1.3 GB from the other or is an equal amount used from each stick? Is it still dual channel even though the full 4 GB isn't used?
Do you think I should get Crucial memory with the lifetime warranty or save some money and just get generic memory from Amazon (1 year warranty- even though it's labelled "Crucial"- from user comments I saw that it really isn't.)
Reply 74 of 735, by agent_x007
A-L-E-X wrote:
Thanks, I used a few different power calculators to come up with 650W/40A 12V rail being my requirements, so the 700W/50A 12V ra […]
Yes, Yes, Yes, Yes, Yes, Mine is better in every way 😀 (except size, but that's a personal thing 😁), Equal, Yes, 667/800MHz CL5 modules.
I don't trust "generic" (altho I never used "Generic" memory past SDR-type).
Reply 75 of 735, by valentyn_l
Well, the minute I get my 775Dual VSTA I'm gonna pop a Q6600 inside it and order an HD 5850 to go along with it. Should make for a nice upgrade from my current old-school build with a P4 and 7600 GS.
Reply 76 of 735, by agent_x007
Sadly, only 4CoreDual series supports Quad Cores 🙁
Reply 77 of 735, by A-L-E-X
Yes, I've found that "lifetime" warranty quite useful. I'm impressed with the HD 5870 scores, it looks like Radeons still perform better with 3DMark (this is something that goes back generations- AMD must be optimizing them somehow.)
I see you have quite a collection of GPU's- that 4670 is of the AGP variety isn't it? I think it's the most powerful card made for the AGP port.
As far as memory is concerned, are you using DDR2-6400 or DDR2-5300? From what I see in BIOS, I didn't know that you could use DDR2-6400 (and even when you use DDR2-5300, the system seems to be most stable when run at DDR2-4300 speeds.)
Reply 78 of 735, by agent_x007
HD 5870 was based on architecture made to work with DX9(c) in mind (VLIW5 "loves" DirectX 9, because it can easy utilise all 5 ALU's at the same time). It goes back all the way to HD 2900 XT, and the first DX10 GPU from AMD.
GTX 580 was made to work best on DX11, so it isn't best suited for Win XP (also, drivers work in Radeon favour too).
Yes, all GPU's from my graph are AGP (including 4670) - which clearly isn't the fastest AGP card (it's the newest one, but not the fastest), and excluding GTS 450 and Radeon HD 5870 (duh ;P).
I don't want to go Off Topic here, but with Core 2 Duo and faster CPU's, HD 3850 will be faster.
I was using PC2 6400 CL6 at the time, actual settings (for QX at least) : LINK.
It worked fine on those settings, but I didn't game on it for hours (it was only testing setup, so no need to check if it's 100% stable).
You can use PC2 9600 in this MB, it simply will be clocked down to 667/533/400MHz (depending on BIOS settings).
Keep in mind, that this MB has ~1,9V limit on DDR2 memory without Vmod's.
Reply 79 of 735, by A-L-E-X
agent_x007 wrote:
HD 5870 was based on architecture made to work with DX9(c) in mind (VLIW5 "loves" DirectX 9, because it can easy utilise all 5 A […]
Thanks, what's the "highest" Radeon card that will work on this board- 6900 series? I assume none of the 7000 series cards will work?
Also, what's the fastest AGP card that will work?
Found some more info here
https://forums.anandtech.com/threads/asrock-4 … .311715/page-38
it seems like Radeon PCI-e 2.1 cards do work, as all cards from the 5000 series on are 2.1 cards, maybe even some 8000 and 9000 series cards work. Nvidia didn't make any 2.1 cards, they went straight from 2.0 to 3.0
https://en.wikipedia.org/wiki/List_of_AMD_gra … rocessing_units
https://en.wikipedia.org/wiki/List_of_Intel_g … rocessing_units
https://en.wikipedia.org/wiki/Comparison_of_N … rocessing_units
