Reply 5740 of 30906, by PhilsComputerLab
- l33t++
Reviewing two products for data transfer of IDE hard drives to USB 3.0.
There are a lot of USB 2.0 devices out there, but not USB 3.0 it seems. There are the "loose" adapters, they are more flexible as you can also use optical drives, and there are the docking types which are a bit nicer to use in a permanent setup.
Still doing some tests, but a bit surprised at the transfer rates of older IDE drives. I expected them to be faster, they do around 40 MB per second for a 80 GB model. Both take 2.5" as well as 3.5" drives and will come in handy as I had no such solution yet.
